Philips 3PFL5606H/12 - good image for 3s / corrupted for 3s and so on
    Re: Philips 3PFL5606H/12 - good image for 3s / corrupted for 3s and so on
    Damn, no datasheet for that IC... Not even a pin out... Can we see a picture of around this chip?
    • SuperDuty
      • Mar 2011
      • 299
      • France
      Here's a picture of the area.
        They could have at least labelled some things!
        Where do you measure the 22V dropping to 14V?
        This may be VGH which is used by the TFT to select rows... low VGH = scrambled image.
        • SuperDuty
          • Mar 2011
          • 299
          • France
          I measure that at the two diodes, labeled D7106 and D7107, they're just above the small mosfet Q7106 on the left of the picture.
          What's strange is that the image becomes scrambled so regularly.
          • SuperDuty
            • Mar 2011
            • 299
            • France
            An update, I finally got my hands on a universal remote and managed to do the firmware update...no change
            I've unplugged the CN7102 connector and the left part of the image is stable now, with the right side being white. If I plug the CN7102 and unplug the CN7103, I get the right side scrambled...so is it a flat panel problem ?
            • alro7779
              Philips 32PFL4901/F8 BA5DFGG0201 1 Backlight is present but no image
              by alro7779
              Hello there!
              Have this Philips with no image at all. When I plug it to the outlet, it turns on without pressing the power button, and after a moment, it turns off, then starts again. I checked the 12v and 3.3v voltages on the main board connector that goes to the T-con, but it only has the former (12v). Any clues, guys?...
              08-07-2025, 11:53 AM
            • tuner2000i
              Philips 65PUS8518/12 distorted image after main board replacement
              by tuner2000i
              hello everyone,
              I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
              The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
              07-15-2025, 01:15 PM
            • malekservis
              Philips 58PUS8536/12 Backlight ok, no image
              by malekservis
              the TV turns on fine, seems to be working, but shows no image outside of a thick white vertical line as it turns on that also disappears almost instantly, and then it's just backlight. I've tried unplugging either side, but still can't get an image. I suspect it's a panel issue, but thought i'd ask some smarter people to confirm. I haven't found any weird readings, but then again i'm just randomly poking around with a multimeter.
              Any information would be appreciated....
              08-07-2024, 07:48 AM
            • waakye
              ASUS ROG G750JM turns with no image and turn it's off within 7 seconds
              by waakye
              I was giving this ASUS ROG G750JM that exhibit the following behavior:
              When you press the power button, the computer turns with no image and turn it's off within 7 seconds. The battery charges when I connect the AC power. I tried flashing the bios with the uSB method and pressing Ctrl + Home and I can see the bios upgrade on external monitor.
              My issue is the laptop doesn't stay on for a long time and turn itself off.
              Any lead on how to resolve this will be appreciated.
              I cannot boot in windows and no liquid damage.
              Thanks in advance.
              09-13-2024, 08:10 PM
              HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
              This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
              09-12-2024, 02:20 PM
