Service/repair rates for panel replacement
  • ryan74
    • Oct 2012
    • 471
    • usa
    I'm wondering what you guys charge for labor in general or if you replace a panel.
    I just replaced a panel on a Toshiba 42zv650u.
    Panel cost $120 used-I got lucky
    I was thinking of $150 total
    Keep in mind I'm not a professional like some of u.
    Re: Service/repair rates for panel replacement
    Well, I've never done it, but it's a tough job, and you can break or scratch the new panel. So I'd probably add a 33~50% margin, to compensate for my personal screw ups.
    • capkid
      • Oct 2010
      • 1339
      I've replaced a panel in the TV I'm using right now as my second PC monitor. I found one in good condition on eBay for about $70. That was a couple years ago when flat TVs had higher retail values, and I only replaced the panel because the TV has a DVD player; I was planning on mounting it in my garage. The TV is only 26", so it was obviously easier to justify the shipping cost. The panel wasn't too terribly difficult to replace on this particular TV. I've taken apart a 32" plasma in an attempt to remove cigarette odor - that was a nerve-wracking experience.
      I'd probably charge about $50/hr, but replacement panels are hard to find and not normally worth the expense vs replacing the TV. So, I doubt there's much of a market.
      LG Plasma Mal-Discharge Correction Service
        LCD LED TV Service Menu Codes
        TCL LED TV Service Menu Code
        LG LED TV Service Menu Code
        10-31-2024, 03:58 AM
      • Storyteller12
        QN55Q60R Service Menu Panel Help
        by Storyteller12
        I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
        I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
        I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
        the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
        01-13-2024, 01:57 PM
      • JayFixesIT
        LG 65UH9500 TV Panel replacement seal?
        by JayFixesIT
        I am in the process of replacing the backlight boards on the LG 65UH9500 TV. It requires the separation of the front glass/panel to get to the boards. The panel is help on to the frame with some kind of strips that I cannot reuse to adhere the screen to the frame. Anyone have any experience/Ideas on what I can use to securely hold the 65" Panel to the frame. I would hate for the panel to fall face forward. Thank you in advance....
        09-08-2024, 11:15 AM
      • howardc64
        LG 49UJ6500 LCD panel lighter band that goes away
        by howardc64
        49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
        Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
        02-19-2023, 12:13 AM
      • triplefour
        SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
        by triplefour
        TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
        tcon is built into mainboard.
        Only one cable goes to panel boards.
        there is a cable from one panel board to the other that links them.
        cost cutting measure that results in us having harder time to diagnose.
        removing the link to the second panel board allows TV to stay on with stable backlight but no image.
        used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
        07-28-2022, 07:59 PM
