Panasonic tc-p42c2 to tc-p42c2 panel swap?
  • microvibe
    • Mar 2013
    • 275
    • canada
    someone selling locally a tc-p42c1 tv powers on screen just red and says looks like water damage in top left corner, i have a tc-p42c2 with a shot main board but my panel is good and so is rest of boards would a panel swap or board swap be possible? what would make screen stay all red ?
    Re: Panasonic tc-p42c2 to tc-p42c2 panel swap?
    Sounds like SS board failure on that one.
    Only way it could work is if SC, SU, SD and SS are all the same which is probably not the case as they are different model years (2009 and 2010 I believe.)
    • r3vsEngIT
      Sony Panel Swap Experiment 65x900h with the panel from a 65x930d
      by r3vsEngIT
      65x900h with the panel from a 65x930d.
      900H: model yr 2020, Samsung panel
      930D: model yr 2016, Innolux panel
      spec wise the panels are the same. the drivers and tcons are obviously different but what made me want to give this a try is that the wiring diagrams for the data signals going into the tcon for each tv were nearly identical. there are only a couple pins that i am unsure about and that is what brings me here.
      the 930d has the DPS board where the 900h has none, however, if you follow the pins to the BM1 it would appear that the signals...
      07-11-2023, 11:11 AM
    • howardc64
      LG 49UJ6500 LCD panel lighter band that goes away
      by howardc64
      49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
      Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
      02-19-2023, 12:13 AM
    • triplefour
      SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
      by triplefour
      TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
      tcon is built into mainboard.
      Only one cable goes to panel boards.
      there is a cable from one panel board to the other that links them.
      cost cutting measure that results in us having harder time to diagnose.
      removing the link to the second panel board allows TV to stay on with stable backlight but no image.
      used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
      07-28-2022, 07:59 PM
    • Storyteller12
      QN55Q60R Service Menu Panel Help
      by Storyteller12
      I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
      I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
      I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
      the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
      01-13-2024, 01:57 PM
    • Ancient1
      I'm stuck . Panasonic TH-L32U20M panel's boards issue
      by Ancient1
      Hi
      The TV seem to start ( blinking green) but goes into blinking red. No display and or backlight. Full view photo.
      Actions :
      1. Disconnected Panel's Right, 2nd, board : TV comes ON (steady green , no blinking red )
      1a. You can see in two photos the B/W screen , fading blue "HDMI12" , and the wierd sides of the image, like an old CRT.
      Obviously the fault is from or on the Right, secondary board
      2. I taped the Flex tracks, ~2 tracks at a time- see Photo. The issue seems to be on the V lines (Assuming Data...
      09-03-2023, 03:51 AM
