Samsung LN52A- Vertical lines- Not T-Con
  • moegilla
    • Oct 2012
    • 29
    Sup fellas/ladies been a while.
    I have a Samsung LN52A550p3f with vertical colored lines in one section. Replaced the T-Con board. No Dice. Re-seated and switched the flat cables to see if if was one of them, no dice. So its the panel right? Anything that can be done? I've read that one of the little caps or resistors integrated into the board that attached to the panel could be the problem and wiring around them could solve the issue.
    So here are a few pics. I completely disassembled , have the panel out on chairs as you can see. I have a multimeter but im not much of an electrician. I was attempting to get readings across resistors but not even sure if I was doing it correctly.
    Thanks in advance!
    Re: Samsung LN52A- Vertical lines- Not T-Con
    This is almost certainly a bad LCD panel.
    • moegilla
      • Oct 2012
      • 29
      any potential fixes?
        Probably not. I expect the IC on the tab bond has failed, which would not be repairable.
        • tibimakai
          • Jan 2012
          • 3680
          If you are touching the ribbon cables at the top of the panel and the lines are changing, then probably can use bud's method, but it's very hard to make them all disappear and to stay that whey, while you are putting it together. There are no guaranties that it will last.
            The inputs, at the driver board, are usually uncorrelated to pixels. Just overall data for the block of pixels that IC drives. So any pressure there is actually pressure on the IC itself making the problem go away, possibly like BGA-bonding problems with Xbox 360 / PS3.
            • snake91876
              • Feb 2013
              • 236
              I beat my brains out trying to fix a 46 like this and eventually figured out it was a bad lcd panel. I could never change the picture pressing on the tabs anywhere. Mine would come on and heat up and get worse and worse.
              • Falki
                Colorful LCD Vertical Lines on Samsung ue55es8090
                by Falki
                Hello there, ive recently found an older 55inch Samsung SmartTV.
                A similar issue has been posted as well but also with no actual response ...
                08-12-2025, 04:19 AM
              • Stanley1843
                by Stanley1843
                06-29-2024, 11:54 AM
              • polaro
                Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
                by polaro
                Greetings,
                I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
                08-27-2022, 08:46 AM
                09-07-2024, 05:50 AM
              • Anonmis
                Samsung 55" UN55JS9000 - Pink vertical lines due to chipped LCD panel?
                by Anonmis
                Hello all, I was recently repairing my Samsung 55" UN55JS9000 tv from the common burnt backlight LED's and cracked light guide panel issue. After replacing the LED's and putting the TV back together, I tested the tv and all I was getting was sound but no image. Somewhere along the way (could be related to the next issue) the T-Con board became damaged and after replacing it I have made a little bit of progress but now have bright pink vertical lines and still no image.
                The bigger issue .... I took the TV apart again and realized that I likely didn't sit the LCD panel correctly...
                12-01-2023, 04:31 PM
