Panasonic 42' PLASMA TC-P42U1 Problems
  • chronos86
    • Apr 2013
    • us
    my problem is when i press the power button i get a Binking red light , blinks once pauses blinks again so on and so on...
    NOV 2009 serial number: LD93310446
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic 42' PLASMA TC-P42U1 Problems
    sounds like 1 blink, SOS1 fault code. Most of what I've read in the manuals it's the A-board. Never experienced it personally.
    • chronos86
      • Apr 2013
      • us
      That 2nd file [panasonic_tc-p42u1_chassis_gpf12du.part2.rar] , i cant open it .
      heres a pic of the a board
      • halobender
        • Apr 2013
        • 36
        Don't know anything about this set but the file that was uploaded is a 2 part file for some odd reason. Not sure where to find part one but you might google the file name but change part 2 to part 1. Also the fourth pic in the original post the board labeled S appears to have bad solder joints possibly burn marks around the transistor blocks. Is it just a strange effect added by the camera?
        • tw2005
          • Oct 2011
          • 6458
          That's what happens when you're in a rush.
          • jm1234
            Panasonic plasma TX-P42ST50 - 6 blinks
            by jm1234
            anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
            It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
            I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
            I checked that board for any obvious faults...
            05-22-2024, 06:59 AM
          • Alicat
            Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
            by Alicat
            Stopped by this site trying to fix my parents Panasonic Plasma TV.
            Model number is TH-50PZ85U
            Power comes on and the red power light stays on solid.
            Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
            I also hear a few clicks.
            I also think my parents said there was a thunderstorm and the TV failed after that.
            Section 6 in the service manual talks about power and no screen,...
            10-30-2024, 10:09 AM
          • nick31
            Panasonic Plasma ST50 TC-P55ST50 P55ST50 8 blinks
            by nick31
            My Oct 2012 panny plasma quit working yesterday.
            It was on when it happened. It let out a bit of burned plastic/circuit board smell. I was not able to find any burned parts though.
            Now it produces 8 blinks. According to the repair manual, that points to SS/SS2 board(s).
            I completed the steps in the guide: unplugged SS33, the TV turned on with a black screen, no blinking codes. Then I checked the continuity between pins 1 and 2 of the connectors SS52, SS54-SS57. The continuity is ok in all of them. Guide suggests to replace SS/SS2 boards so I placed an order...
            04-21-2021, 09:56 AM
          • stecos
            Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
            by stecos
            Hi everyone!
            I happened several times, in the search for help from the web, to consult this very interesting forum.
            So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
            Having said that I come to the gist of my post on the forum as the title suggests.
            For my passion for technology I'm now collecting several...
            11-28-2022, 11:39 AM
          • Biruslapio
            Panasonic P58V11B 8 and 12 blinks error "fix"
            by Biruslapio
            Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
            Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
            04-13-2021, 07:13 AM
