Panasonic TV
  • foxy
    • Sep 2011
    Panasonic TV
    Hi< I have a Panasonic Plasma Viera TC-P50U2 50 inch TV . When it first starts up the picture is fine but after it warms up i get horizontal bars that run from one side of the screen to the other side. These bars are constantly flipping.Has anyone experienced this problem and have a solution. Thanks pete.
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TV
    https://www.badcaps.net/forum/showthread.php?t=28107
    • mostachio
      Looking for help diagnosing a 65" Panasonic Viera TV - TH-65DX700Z (Turns on - Clicks - Turns off)
      by mostachio
      Hi Badcaps,
      I've had a friend discard a TH-65DX700Z Pansonic Viera Television and I've decided to have a go at repairing it. If possible could I please get some advice in terms of diagnosing the problem so I can purchase the appropriate parts for repair whether it be components, a repair kit or a replacement board. I am happy to post pictures if required.
      TV Details:
      Model # - TH-65DX700Z
      Symptoms:
      The television turns on and displays a picture then makes a clicking sound and turns off.
      I haven't opened it up yet but...
      09-04-2024, 02:32 AM
    • Ama Chur
      Panasonic Viera LC470EUN (SE)(M2) T-Con issue?
      by Ama Chur
      After watching some youtube videos and checking some forums, I'm at a loss. With both ribbon cables connected, we have no image. With the left one pulled out, the screen is black and white, split down the middle. With the right cable removed, it is all black. Backlight is working fine and we have sound and can open applications. We are strapped for money right now and are hoping to repair whatever the issue may be. I think the TV was manufactured in 2012, so I'm aware that may not be possible. Edit: Found a single vertical line of blue pixels on the left side of the screen with one of the ribbon...
      02-21-2025, 08:12 PM
    • badcappo
      Dead Panasonic Viera TX-P65STW50 Plasma TV
      by badcappo
      Hello, got a ST50 plasma TV for repair. No signs of life, not even blink codes. Opened it up to check the power supply, type MPF6914. Apparent issues from visual detection and measuring for shorts:
      Diode type G972s6 - D101 with a short
      Mosfet 06N90E - Q301 shorted
      Fuse T5AH 250V - F103 blown
      Diode D301 shorted
      Relay DG1U-17VDC II - RL001 blown
      I have not found a circuit diagram. Maybe someone here already dealt with a similar issue? Thanks for tips where else to check πŸ˜€...
      11-24-2024, 11:27 AM
    • J8rda7
      Panasonic Viera TX-L50E6E - no image
      by J8rda7
      the TV has a black screen. Sound OK, backlight OK.
      When I measure T-CON voltages, there is VGL+VGH=0V. After unplug the right side of the screen from the T-con, voltages are OK and half screen works normally.
      I tried to search for any kind of short on the right side, but I had no luck. I have a beginner experience in measuring and repairs of the LCD panels..
      Thanks to anyone who can guide me in solving the problem.. and be patient with my english πŸ™‚πŸ˜
      05-13-2024, 11:04 PM
    • Andre Gilbert
      by Andre Gilbert
      Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
      Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
      11-20-2024, 08:52 PM
