philips 42mf521d/37 no picture - confused. :why:
  • techmadman
    • Feb 2013
    • usa
    hello all i have a philips flat panel lcd tv. the unit just lost display no noise or pops. i have replaced both the lcd inverter main board and slave board as well as power supply, main board (video card) and t-conn board. main board was questionable so sent it back and got replacement with new. so all parts in tv have been replaced and are new, still not picture. if the tv is plugged in and you carefully and slowly unplug the lcd main inverter board the lcd screen will flash. but no power lights come on or anything. any ideas would be greatly appreciated.
    i just don't know what else to look at i have verified proper voltage is geting to all circuit boards.
  • Steve.B
    • Dec 2008
    • 83
    Re: philips 42mf521d/37 no picture - confused.
    I am no expert, but maybe you have a bad lamp that is tripping the cut-out on the inverter? If you search the forum you should find info on telling you how to check.
    Have you shone a bright flash light at the screen when the tv is powered on to see if you do have an image, just no back light? Does the sound work?
    • techmadman
      • Feb 2013
      • usa
      no sound not working but dont have any devices connected, it is disassembled on my table., but no static either. not getting voltage to t-con board, have replaced mainboard twice to make sure the first one wasn't defective. i am getting 24 volts to lcd inverter boards.
        Pictures of ALL of your boards?
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • tuner2000i
          Philips 65PUS8518/12 distorted image after main board replacement
          by tuner2000i
          hello everyone,
          I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
          The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
          07-15-2025, 01:15 PM
        • howardc64
          by howardc64
          07-24-2025, 05:17 PM
        • spantor
          Activate power board Philips 40PFH40009/88 tv
          by spantor
          Hello partners.
          Could someone tell me how to make this Philips TV source work without the mainboard being connected? The model of the board is EAX65423701 (2.1) and the model of the Philips TV is 40PFH40009/88.
          The TV is dead, there is no standby light, however there is a voltage of 12v on the pins ( included 12v VAU ) and 3.2v on the PS-ON pin (see photo) when the power board is connected to the main board. If I disconnect both boards I only get 8 volts on 12v pins. I would like to rule out a fault in the main board by making it work, but so far no one has been able to tell...
          02-11-2024, 05:07 PM
