Another vw42l problem
  • Rofix
    Problem HP Main Board DAG3DCMBCC0 REV C
    by Rofix
    Hello everyone I wanted to kindly ask you for advice I have a problem with this HP Main Board DAG3DCMBCC0 REV C motherboard, the PC does not turn on, the power connector works, 19V arrives, on the first three mosfets there are 19V, the main voltages such as 3.3V and 5V are on the various coils, on the power button 3.3V arrives, I checked the power button and it works, but the PC does not turn on, moreover when I connect the power supply to charge the battery it does not charge, no LED lights up at the moment as the voltage is at 14.7V, the nominal voltage written on the battery is 15.4V, I also...
    12-19-2024, 02:10 PM
  • cheeky2
    by cheeky2
    05-25-2024, 03:27 AM
  • bcstedt
    Samsung PN50C540G3FXZA 50" Plasma, power cycling, Y-Main problem, Canada
    by bcstedt
    Just starting to crack into this one and wanted to get the ball rolling.
    At power on (plug in), power light on, relays click, repeat (sometimes)
    After disconnecting Y-Main from SMPS power stays on and boot up jingle is heard from speakers
    Removed Y-Main for inspection and testing
    This pic from:
    PN50C540G3FXZA Fast Track Troubleshooting Manual - Rev 1/10/12
    12-15-2023, 10:30 AM
  • Dani_2024
    by Dani_2024
    10-28-2024, 05:06 PM
  • Zeonalbasta
    Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
    by Zeonalbasta
    i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
    The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
    09-13-2024, 01:17 PM
