LG 42PC5D Plasma no pic but sound
    Re: LG 42PC5D Plasma no pic but sound
    Yes, Q1, sorry didn't say.
    The diodes may look bad, but diodes rarely become non-uniformly leaky. They almost always fail shorted. As do FETs.
    • maddog310
      • Apr 2010
      • 51
      Readings from Q1
      D+ S- OL
      G+ S- OL
      G+ D- OL
      S+ D- 12. 14Mohms
      Measured out of circuit, so it's bad? That heat sink was very hot.
      Why would some diodes measure one way and others another way?
      Thanx for all the help Tom66, without the help of you or others on this site and the internet, we probably wouldn't be able to fix our (my) electronic devices.
      Where should i be looking now in relation to that fet, could that be the only part that went!
      I did measure the IPM's and they show as no good also.
      • maddog310
        • Apr 2010
        • 51
        ttt
          Circuit can be different for some parts, so you will measure differently.
          You need to test those Q's on diode mode.
          • maddog310
            • Apr 2010
            • 51
            Q1 diode mode
            D+ S- OL
            G+ S- OL
            G+ D- OL
            S+ D- .482v
            • maddog310
              • Apr 2010
              • 51
              Rechecked in diode mode.
              Q1 tested out of circuit
              D+ S- OL
              G+ S- OL
              G+ D- OL
              S+ D- .482v
              S+ G- OL
              Q2 tested in circuit
              D+ S- OL
              G+ S- OL
              G+ D- OL
              S+ D- .469v
              S+ G- .196v
              I am going in the right direction, where should i be checking next?
                Q1 good, Q2 appears bad - try retesting.
                • maddog310
                  • Apr 2010
                  • 51
                  Q2 tested out of circuit
                  D+ S- OL
                  G+ S- OL
                  G+ D- OL
                  S+ D- .460v
                  S+ G- OL
                  I guess both are good, that heat sink was very hot though.
                  Looking in the wrong place, likely the ipm's i checked earlier, which are a known weak point. I thought maybe something else might of been shorted.
                  Should i replace 1 or both ipm's?
                  Ysus # 6871QYH063A, module # AEF31675201(A) 0651SANY(P), Zsus # 6871QZH067(A), same module as above.
                  Do they have to replaced with exact match or with something close?
                  Any suggestions on replacements.
                    I don't know to be honest. Do you have screen glow in a dark room?
                    • maddog310
                      • Apr 2010
                      • 51
                      No i didn't try it in a dark room.
                      I will put those fets back in and try.
                      • cudadave
                        • 3
                        • usa
                        #31
                        did anyone know what the F46J diode was? on the ysus board.
                        • cudadave
                          • 3
                          • usa
                          #32
                          does anyone know what the diode F46J is? on the ysus board.
                          • cudadave
                            • 3
                            • usa
                            #33
                            Originally posted by cudadave
                            does anyone know what the diode f46j is? On the ysus board.for samsung plasma tv
                            11
                            • ArMaaN376
                              Samsung PS51E550 Plasma TV
                              by ArMaaN376
                              I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
                              Opened TV cover & observed foll
                              a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
                              b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
                              c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
                              How to confirm Y -Buffer board...
                              06-19-2024, 04:05 AM
                            • jm1234
                              Panasonic plasma TX-P42ST50 - 6 blinks
                              by jm1234
                              anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                              It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                              I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                              I checked that board for any obvious faults...
                              05-22-2024, 06:59 AM
                            • KYBOSH
                              Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                              by KYBOSH
                              Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                              No picture but you hear the TV static (white noise) playing loud and clear.
                              The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                              But it seems they didn't get too far and just left it.
                              When I first took a look I was amazed at how pristine the inside looked.
                              Its as if the TV had been in a time capsule.
                              Caps looked like they were just pulled off the self.
                              Copper coils had no sign of corrosion on...
                              02-01-2023, 11:10 PM
                            • chazh
                              LG 60PS11-UA 60-inch 1080p Plasma TV-service lit & video help needed
                              by chazh
                              This is my first posting, so forgive me everyone in advance if I made mistake(s) in my posting.
                              I know there have been much about this plama tv already and I have read through most what I could find. However; I still have not come across any service lit/schematics for this tv. I even looked for the 50PS11 which would be basically relevant other than display size. Anyone know to find the documentation would greatly be appreciated.
                              The set that I have has issues with lower third of screen being dimmer than the above portion. From my past experiences with tube, solid state,...
                              09-01-2025, 08:56 PM
                            • porfyriadhs
                              Samsung Plasma PS51D6900DS Bootloop
                              by porfyriadhs
                              Hello . I have a problem with a samsung plasma tv stuck in bootloop . The TV is Samsung PS51D6900DS plasma smart tv .Need help if anyone have any suggestions
                              Thanks a lot !!
                              10-19-2023, 11:31 AM
