WOW The Secret LG Factory Reset and The Secret Hotel Mode
  • davewilson61
    • 110
    • usa
    To enter Installation menu from the remote control, you need:
    Choose any TV channel (it might not work if other input is selected)
    Press and hold MENU button on the remote control until TV's menu appears, disappears and channel info appears.
    Quickly release MENU button, enter 1105 and press OK.
    If your remote control has no MENU button, use HOME button instead.
    If you have 2012 model and procedure above doesn't work then you'll need to:
    Enter InStart Service Menu
    Press Settings button.
    In the installation menu, you can change the following parameters:
    LG Hotel mode setup (setting restrictions for hotels)
    TV Link-Loader (load/save configuration (TLL file) from/to USB drive)
    Password Change (reset forgotten parental PIN)
    Set ID Setup
    this was how i fixed the key lock and the only 50% volume setting ..tv was in hotel setting....lol..hey tom66 add this to the factory reset list
    for more on this goto.. http://openlgtv.org.ru/wiki/index.ph..._modes_/_menus
    dave
  • Pictureperfect
    • Feb 2017
    Re: WOW The Secret LG Factory Reset and The Secret Hotel Mode
    You are the man , I work for at&t /Dtv and ran into this issue the tv would not switch over to the HDMI... I did this and got it back right thanks for t he info !!
    • Skyscr
      • Nov 2018
      • Ita
      Code 1105 crack all lg TV hotels, many thanks Man!
      • Skyscr
        • Nov 2018
        • Ita
        HDMI input unblocked, lol)
        • Grunder
          • Jan 2016
          • 323
          • south africa
          Hey, this sounds fantastic, I have an LG 42PG60UR which wont display the hdmi inputs when selecting source. I definitely will try this when i do my call-out today.
          I was actually trying to find the specs for my customers LG 42PG60UR which i couldnt find on the net. LG no longer have the main board and last price was ZAR 2400.00. the cost of the set second hand.
          Will make new post for this LG.
          • vinn2
            • Sep 2020
            hi
            my tv is set to turner option and i do want it to be defulted on HDMI option can you help me how to do it.
            when i do put it on HDMI it does not recgnize next time. Every time i turn on it goes back to turner or tv option autometically
            can you please help
            • vinn2
              • Sep 2020
              I bought a bunch of 32lc50c-us model of LG tv currently it is stuck on turner/tv input. I want it to have defaulted on HDMI. I did go to set up menu and tried to put it on HDMI it works but every time I turn of and again turn on it goes back to turner/ tv ....can you help me how do I make it default choice of input as an HDMI not this tv came from some hotel, as I bought it from the hotel liquidator
              thanks a lot in advance
              Originally posted by davewilson61
              To enter the Installation menu from the remote control, you need:
              Set ID Setup
              dave
              • jrosaly
                • Mar 2021
                Hi, were you able to get into the setup menu? If so, what worked for you?
                • handsworth
                  • Oct 2015
                  • 174
                  I bought 10 of these 37" hotel tvs from a liquidation. Easy peasy if you have a service remote. BTW there is a download somewhere to make your smartphone one.
                    LCD LED TV Service Menu Codes
                    TCL LED TV Service Menu Code
                    LG LED TV Service Menu Code
                    10-31-2024, 03:58 AM
                  • sheffieldyorky
                    ZAB/ZAB A,B/ZYJA BLOCK DIAGRAM Acer Aspire
                    by sheffieldyorky
                    Hey there people
                    While working on my Acer Aspire with the OS failing to load, I encountered a motherboard number of DA0ZHQMB6E 0 REV: E. I was getting nowhere fast or slow, for that matter.
                    This is what I tried, but not in any order.
                    Google
                    YouTube
                    BIOS
                    Command Prompt (administrator privileges)
                    On Google AND YouTube, I was getting mixed messages, try this and try that, but when you cross reference the advice it is either the wrong model (even though you enter the correct search term) a YouTube case in point, with the search term "how to...
                    10-25-2025, 02:22 AM
                  • wattage
                    by wattage
                    Hello Badcaps Community,
                    07-13-2025, 04:41 PM
                  • LEONARDO DE FREITAS
                    Chinese multimedia crashes on the home screen, could someone help with the software or factory reset?
                    by LEONARDO DE FREITAS
                    Hello everyone, I have 2 multimedia systems with a 9-inch screen that turns on and only stays on the Android screen. It is very likely a software update. I have 2 software programs here but the multimedia system does not start the installation. Has anyone encountered this problem? I would be grateful if you could help.
                    04-18-2025, 09:58 AM
                  • masterm
                    JVC LT-43C888 (manufactured by Vestel) does not start after trying factory reset, details below
                    by masterm
                    TV: JVC LT-43C888 (purchased in 2018). This is a smart TV with Netflix, Youtube, Freeview and other applications via 'Viewd' app store
                    Problem with TV:
                    - Netflix stopped working so i tried to do factory reset from the TV menu.
                    - I confirmed on-screen but the factory reset did not happen even. It did not take me to 'first-time installation' screen as mentioned in the manual.
                    - After waiting for some time, the TV went into a boot loop.
                    - JVC logo comes on the screen and LED light flashes for some seconds, then it reboots again and the same thing happens
                    04-30-2024, 03:03 AM
