Samsung Plasma PN50A550S1F no power
  • maddog310
    • Apr 2010
    • 51
    Hi all, picked up this television and was told by owner that he went to put it on and it wouldn't power up, no lights.
    I found a blown 12amp main fuse and 2 10v 2200uf samwha caps bulged. I have replaced the caps with panasonic FC caps.
    Now i believe i can power up the power supply with every thing disconnected to check voltages on the connectors! However i don't want to waste a fuse or damage the supply by putting power to it prematurely.
    Should i check voltage regulators or anything else before powering up the board.
    I should say that i have managed to fix half a dozen computer screens, just lately an Acer and a Samsung T200 lcd, both with bad caps. previous fixes were with the help of this site and lots of reading.
    Here are some pics. Any help is appreciated.
    Mike
  • maddog310
    • Apr 2010
    • 51
    Re: Samsung Plasma PN50A550S1F no power
    Ok, will try the pics again.
    • retiredcaps
      • Apr 2010
      • 9271
      If the fuse blew, check the bridge rectifier, big filter capacitor and power mosfet to see if they are shorted.
      --- begin sig file ---
      --- end sig file ---
      • maddog310
        • Apr 2010
        • 51
        Thanks for the reply retiredcaps, i tested the rectifiers by this video, http://www.youtube.com/watch?v=dqkT6hF0O3E
        they test good, DS803 AND DS805, i get a reading one way from - or + to ac, middle pins, nothing between the two middle pins.
        Now testing the large caps, 3 of them? CP810,CP809 and CS813 or just the first two. Do i power up the board and check the voltages and the mosfets your talking about are on the heatsinks. I can test these in circuit in the diode mode on a dmm.
        Mike
          Across the two largest 400/450V caps, test resistance (power MUST be off.)
          Consider building a "lightbulb tester" - put a lightbulb in place of the fuse. If the lightbulb glows permanently when turned on, there is still a problem. If it flashes or goes dim, then the PSU is probably OK.
          • maddog310
            • Apr 2010
            • 51
            Thanks for the reply Tom66, the two large caps 450wv 330uf read around 33 and 30mohms and decreasing. I have checked them a few times with different results, i guess it depends on the state of charge!
            Tested the two power mosfets on the heatsink, i believe thats what they are, QP801 and QP803. the results were.....
            QP801 S+ D- equals 1.053mohms part#20N60C3, GMN642
            S- D+ equals .820mohms and increasing
            QP803 S+ D- equals 1.051mohms part#20N60C3, GIP648
            S- D+ equals.815mohms and increasing
            The meter i have is a auto ranging.
            I made up a light bulb tester with the blown fuse and a 25 watt bulb, but after more reading, i realized the bulb should be 100 or 200 watts. I am going to make one, what size bulb should i use and do i leave all the boards disconnected from the supply?
            Here is a link to the manual, if it helps or if anyone else needs it.
            http://elektrotanya.com/samsung_f43a.../download.html
            Pics of tester and mosfets i tested.
            Mike
              A 25W bulb will do for standby testing, but you need a 100W bulb to try starting up the PSU. TV will not work with it, but it should at least show if there is a fault.
              mohm = Mohm = 1000 kohm?
              • maddog310
                • Apr 2010
                • 51
                Ok, so i will use a 100w bulb, do i connect all the boards to the PS or leave everything disconnected?
                I checked diodes at DB810, DB801, DB802, and DP803........ all tested good. Also checked a few others on the board, they tested good.... reading in one direction.
                What do you think of the values i have in my previous post, good, bad or inconclusive.
                Do you think the 2 blown caps could have caused the fuse to blow, i guess it couldn't be that easy!
                Mike
                  You need to answer my question:
                  before I can tell you if your readings are OK.
                  • maddog310
                    • Apr 2010
                    • 51
                    Sorry about that, it's Mohms. I didn't realize there was a difference for a small m and a capital M.
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      m= milli. M = mega.
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        Mega ohms suggests the components are not shorted.
                        • maddog310
                          • Apr 2010
                          • 51
                          After doing a search i found this out. The meter i have is from crappy tire, used mostly around the house and on cars, checking voltages and continuity. Will be using it on a sled later today, checking a lighting coil.
                          I just realized it has a transistor function, which i could of used a few years ago on a Benq screen. I tested them with the ohm function as i recall.
                          Enough rambling.............
                          I guess my next step will be to power it up with the light bulb, do i connect all the boards or supply only?
                            The transistor function on most multimeters is next to useless, don't bother.
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              In Canada, the choice of a "general" multmeter for the "average joe" is limited to what Canadian Tire, Wal-Mart and Home Depot carry. Even the crappy 830 multimeter is sold for $15 to $20 CDN + taxes.
                              The local electronics store prices their brand name multimeters and most of the merchandise like they have never heard of the Internet or ebay.
                              • maddog310
                                • Apr 2010
                                • 51
                                This is the meter i have.......
                                http://www.canadiantire.ca/AST/brows....jsp?locale=en
                                Upgraded from an analogue meter, if i wanted a better meter i could of went to a jobber joint like Napa or something similar or the electronics store or electrical distributor.
                                For my needs this works.
                                Can anybody tell me if i can power up the PS alone or connect all the boards to it and try the light bulb test?
                                • maddog310
                                  • Apr 2010
                                  • 51
                                  Did the light bulb trick, 100 watter with a couple test leads, bulb did not light........ ps only.
                                  I then reconnected everything back together as i had it all apart for cleaning and testing.
                                  Retested with light bulb and it would come on then off in conjunction with the relay clicking on then off.
                                  I put the fuse in, connected a dvd player and started everything up. Red power light come on then the blue light in the middle, heard samsung start up sounds but no pic. Changed the cables around still nothing...... unplugged everything and reseated buffer cables, looked around boards to see if i missed a cable, and i did. So i connected the ribbon cable to the ymain and powered it all up.............. now have a running tv for now.
                                  Changed two caps and a fuse, got lucky.
                                  Thanks to retiredcaps and tom66
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    You may consider changing all the capacitors on the power supply based on the cockroach theory. Even though they may look good, they could be failing.
                                    • PantherDave
                                      by PantherDave
                                      Hi all!
                                      05-29-2024, 02:01 PM
                                    • CDNBrewer
                                      Samsung Plasma PN43D450A2D No Power
                                      by CDNBrewer
                                      Hello, I have a Samsung Plasma TV - Model # PN43D450A2D
                                      This was my parents TV and the initial symptoms were that the display was hard to turn on with the display making various clicking noises until one day it would not turn on anymore.
                                      I took a look and found a couple 1000uF capacitors (i believe on the low voltage size) that had leaked out their electrolyte and did not test well on a tester. I replaced them but still no dice.
                                      When the TV is plugged in, there is no clicking, LED status lights (on PCB boards or the front display) and the power on button...
                                      03-02-2025, 04:59 PM
                                    • GLISIT
                                      by GLISIT
                                      01-16-2025, 02:29 PM
                                    • lp20th
                                      Samsung Plasma TV Power Supply Issue
                                      by lp20th
                                      I have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
                                      11-28-2023, 10:28 AM
