Neovia NEOPL-4950 Plasma.. the dreaded red dots :-(
  • JonathanAnon
    • Jul 2012
    • 457
    • Ireland
    Hi guys,
    This TV is perfect when turned on, but after about 15-20 minutes of use, red dots appear on the screen and get progressively worse.. What I've tried.
    - Replaced two main large filter caps (that were bulging) on the power board.
    - Tweaked Vs, Va, Vscan etc to the values on the back of the panel
    - Changed the pots on the Ysus board (I read through one of tom's threads with the instruction on how to do this).
    I've noticed that when I use freeze spray/fans on the spot below the Ysus bank of caps, the problem disappears..
    http://videobam.com/XlrmE
    The hottest part seems to be the heatsink for the FETs on the IPM. But I cannot narrow it down further because the components are very close to each other. When I use the freeze spray in the white circle on the image below, the problem stops..
    But the freeze spray has a wide enough dispersion area (even with the straw to direct it) so really any of the components in that area could be causing the fault. Oh, and I tried heatsinking that 16 pin chip, but to no avail.
    The Ysus board is a Samsung LJ41-02088A Rev1.1 (other number on board LJ92-00981A) dated 08, so it seems that it may have been changed already given that the TV is from 05/06. I would just buy a new Ysus if I thought it would work with the other boards, but I know there are issues with matching the boards..
    Any advice appreciated..
    Re: Neovia NEOPL-4950 Plasma.. the dreaded red dots :-(
    Try dropping Vscan by a bit; keep Vs and Va as-is.
    • JonathanAnon
      • Jul 2012
      • 457
      • Ireland
      that was the first thing I tried tom.. I focussed on Vscan (alone) having read a few different documents about similar issues with plasma screens and dots.... I turned the pot for Vscan counter clockwise, in stages, down to about 5-10 volts below the value on the back of the panel... But it didnt make any difference at all..
        Did you try Yrr/Yfr?
        • JonathanAnon
          • Jul 2012
          • 457
          • Ireland
          Yeah I found the thread you did which you advised on changing the pots on the y sus board.
          http://unielectronica.com.co/imagenes/LJ41-02088A.jpg
          You'll notice there are pots for Vsch, Yerr, Yfr, Yfrr, Yrr1, Yfrr1 ... I've tried toying with all of these, separately.. I started with the Yfr and Yrr, about a 90 degree turn of the screwdriver each time to the point where they would move no more.. Then I moved the pot back to it's original position and did the same with the other pots.. Nothing helped.
          At this stage I was trying to focus on the fact that I can clear the dots by cooling the section that I pointed out in the other image.. But if you think it's worth having another shot at the Ysus pots, I'll certainly give it a shot..
            I would consider those two electrolytics next to the IC.
            • JonathanAnon
              • Jul 2012
              • 457
              • Ireland
              Yeah thats the next step I was gonna take with this y sus board.. they seemed okay with the ESR meter, but I didnt take them out of circuit.. I replace the three (two smd and one through hole) around that area just to rule them out..
              • JonathanAnon
                • Jul 2012
                • 457
                • Ireland
                Just to confirm those SMD caps.. are 22uF 35V with tolerance of 5% (J).. right?
                  More likely 20% tolerance.
                  • JonathanAnon
                    • Jul 2012
                    • 457
                    • Ireland
                    okay I went down to my workshop, and took away the board with me.. Went through all my old boards but I dnot have a replacement for the two SMD caps.. So I'll have to order those in..
                    However, I've pulled out the through hole 20V 22uF electrolytic cap (to the right of the IC) from that section and it's measuring 0.5uF and 16ohm ESR... I went through all the caps the last time I had this board out, how the hell did I miss that..
                    • JonathanAnon
                      • Jul 2012
                      • 457
                      • Ireland
                      Just getting back to this now.. I changed that dodgy capacitor about two weeks ago, but didnt get a good chance to test it after... Have it on test with my PC, and it's about 90% sorted... There is still random speckles of green and red on a full white screen, but there is no full screen non discharge like in the video...
                      Trying to tweak it now to sort out the issue of the random red and green dots, so I have the back off it and am playing with the Vscan... They put the pot in THE most awkward spot, I have to turn off the TV to get at it safely..
                      • JonathanAnon
                        • Jul 2012
                        • 457
                        • Ireland
                        Okay again after replacing that cap, the dots were down to about 10% of what they were.. Tinkered around with Yr, Yrr, Yerr, Yvsh on the Y Sus board but none mad any difference... Put them back to where they were and had a go at the Vsc pot on the PSU board... This did not affect things either.. Moved the Vs on the PSU and it's almost perfect now..
                        • r-p
                          Maldischarge-link that fixes it with replacing caps
                          by r-p
                          Starting this thread because Capkid doesn't seem to be reprogramming controlboards anymore (LG 60PZ950 with red maldischarge) and my game-plasma also has maldischarge (Hitachi 42PD3200). So I will grasp at straws to keep them running. I am extremely bad at throwing stuff away.
                          Is there any merit to this link?
                          Very short version: Specific caps seem to loose their capacitance and/or increase their ESR. This may cause the maldischarge. Replace them with better/bigger/newer ones and problem solved.
                          From the limited knowledge I have on the subject, I think...
                          01-21-2020, 05:16 PM
                        • PlasMatt
                          LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
                          by PlasMatt
                          I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
                          09-20-2025, 06:50 PM
                        • Truncatedhose
                          Help repair this relic? Philips 42PF7220A/37, pulsing buzz from YSUS
                          by Truncatedhose
                          Greetings all!
                          Originally this set had the usual messed up video symptoms such as: horizontal lines, weak, grainy video, bottom and top of picture differ in intensity of problem. It also seemed to slow to turn on or show the messed up picture.
                          Seemed like must be YScan/buffer board failure. Ordered buffer boards from my distributor which were supposed to be original/new and also from another distributor, I ordered the YSUS because I wanted to replace it for preventative maintenance. (also, the YSUS had a bulged cap, so there was even more reason to suspect it could...
                          07-04-2018, 10:59 AM
                        • ArMaaN376
                          Samsung PS51E550 Plasma TV
                          by ArMaaN376
                          I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
                          Opened TV cover & observed foll
                          a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
                          b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
                          c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
                          How to confirm Y -Buffer board...
                          06-19-2024, 04:05 AM
                        • jm1234
                          Panasonic plasma TX-P42ST50 - 6 blinks
                          by jm1234
                          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                          I checked that board for any obvious faults...
                          05-22-2024, 06:59 AM
