Samsung "LN40A450C1DXZC" Lines On TV Screen Problem, How do I fix?
+ More Options
Posts
  • whitezombie455
    • Mar 2013
    • 9
    Hi there I am very glad I found these forums. First off thank you in advance for any help on here I appreciate it. Okay, so my problem is that my tv has small thin colored lines that are on the left side of the tv screen. There is also a thick see through colored line on the left side of the tv screen. The lines do show overtop of the menus. Here is a picture showing the issues:
  • Mt.Man
    • Jun 2012
    • 53
    Re: Samsung "LN40A450C1DXZC" Lines On TV Screen Problem, How do I fix?
    You have a bad LCD panel.
      And it is unlikely to be a tab bond problem.
      • whitezombie455
        • Mar 2013
        • 9
        Oh how do I fix the LCD Panel???
          It is not repairable in most instances. The actual LCD driver chips which are heat bonded to the panel are defective. It is a common issue with the A-series as well as some B-series Samsung LCD.
          • whitezombie455
            • Mar 2013
            • 9
            Is this problem like you said only specific for my tv model? If it isn't specific to my model I think my uncle had the same issue and he fixed it but he had a different tv so I am not sure if the same solution he used will work for my tv.
              It is specific to a large number of 2009~2010 Samsung LCD TVs I think. Samsung are aware of the issue but will probably fob you off.
              • tibimakai
                • Jan 2012
                • 3680
                ...include 2008 too.
                • whitezombie455
                  • Mar 2013
                  • 9
                  Hmmmmm... Anyone have any actual solutions? Other than buying a new tv of course lol...???
                  • whitezombie455
                    • Mar 2013
                    • 9
                    Umm what I meant was like is there anything I can buy and do to fix the problem myself?
                      A new LCD panel, which will cost from 70~80% of the price of a new TV. Not worth it in most cases. Sorry.
                      • whitezombie455
                        • Mar 2013
                        • 9
                        Okay well thank you... All I need to do now is explain this to my father lol... I'm sure we'll end up trying what my Uncle did... But thank you nevertheless.
                        • Chrissygizmo
                          Sony KD-55XG9505 lines on screen problem
                          by Chrissygizmo
                          Hello again everyone,
                          This is my latest mission, to try getting this Sony tv back to normal working order…
                          I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                          02-19-2025, 11:31 AM
                        • Chrissygizmo
                          by Chrissygizmo
                          02-10-2025, 12:33 AM
                        • Runlinc
                          Samsung QE50Q60TAU - Horizontal screen lines
                          by Runlinc
                          Hi everyone, the tv was in a continuous reboot cycle. To get the best screen image i can I taped the VGH and VSS pins on the left side buffer board joining ribbon.
                          I am left with a good image apart from the black horizontal lines that I cannot get rid of.
                          I cannot find anything on the buffer boards that has shorted.
                          Do you think there is anything i can do to eliminate the lines, or are they caused by an internal panel short and the image cannot be impoved.
                          Many thanks for your assistance
                          05-14-2024, 07:40 AM
                        • mmccomputer
                          problem with replacing lcd screen
                          by mmccomputer
                          I have an HP model : 14-cf0011nf and I want to change its display screen (it has an original 14" full HD TN 30 pins panel) which works without problem but I want to put another screen with an IPS panel, the problem is that I tried several screens but there is no display except with the original screen, I never had this problem before I changed hundreds without problems but this PC is not 'accepted than its original screen
                          otherwise on the motherboard it displays edp and I don't know, do the panels I tried only work with the LVDS protocol?
                          If anyone has any information on the subject...
                          12-15-2024, 03:44 PM
                        • Chrissygizmo
                          samsung galaxy ao2s very temperamental after screen replaced
                          by Chrissygizmo
                          Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                          Ive eventually managed to get it on and working but it's very temperamental...
                          The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                          05-26-2024, 12:05 AM
