L.G. PDP42V7 chassis Black screen, only a few random pixels here and there...
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    This was the fiest plasma that Ive worked on, since I got this, Ive played with a Philips --that has no adjustments at all --with its own issues.....
    This L.G. had a blown IPM on the YSUS as well as D28 and a MOSFET near the top small heatsink when I first checked it.
    A friend located a spare board that didn't have any shorts present on the IPM or other parts. We dont know if it was a good or bad board....
    Fitting it I was presented with a black screen with just a sprinkling of random illuminated pixels of different colours.
    Any ideas?
    TELEFIX
    Re: L.G. PDP42V7 chassis Black screen, only a few random pixels here and there...
    Can you see the screen glow in a dark room?
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      Well--To check the screen--Ive got to lift it a little upright--Its screen down on the floor. I did look for the usual glow--but there appeared there was none, only these random lit pixels sprinkled around, some winking a little...
      The room isn't strongly lit and the screen was well shaded as its face-down....
      TELEFIX
        It's quite important, because no glow with sparklies is often a Z-sus or Vzbias fault.
        • Alastair E
          Chief Womble
          • Mar 2013
          • 1963
          • U.K.
          OK--I'll check now in a bit!
          Ive put the set aside in a corridor--that can be made completely dark. I'll power it up and check for the glow! and let you know. Probably be a half-hour or so....
          Forgot to add, The IPM's (Both Z and Y) get mildly warm.....
          Cheers Tom, Thanks for your great work here!
          TELEFIX
          • Alastair E
            Chief Womble
            • Mar 2013
            • 1963
            • U.K.
            No--There's no glow at all. Ive lost the pixels too this time around...
            TELEFIX
            • Alastair E
              Chief Womble
              • Mar 2013
              • 1963
              • U.K.
              Ive checked and set the Vy and Vsc voltage across the two resistors on the Ysus--they were only slightly out, didnt make a bit of difference.
              Where would I be checking for Zbias on the Zsus?
              TELEFIX
                I think this set does not use Vzbias but I'd need pictures to be sure.
                • Alastair E
                  Chief Womble
                  • Mar 2013
                  • 1963
                  • U.K.
                  These are the same type boards used in the set--
                  http://www.allmatrix.fr/boutique/ima...p_lg42v7-z.jpg
                  TELEFIX
                  • Alastair E
                    Chief Womble
                    • Mar 2013
                    • 1963
                    • U.K.
                    The above pic shows my YSUS but wrong ZSUS.
                    Here's my ZSUS--
                    http://www.ebay.co.uk/itm/42-HITACHI...item460b981140
                    There's very little on the Zsus asnd nothing there appears faulty...
                    TELEFIX
                    • Alastair E
                      Chief Womble
                      • Mar 2013
                      • 1963
                      • U.K.
                      I think what I'll do later, is go through all the settings again, make sure they are all as correct as possible--Then dig the Scope out, see what drive waveforms we find in YSUS and ZSUS.
                      That should at least localise the fault to one or the other boards, and go from there....
                      Hope my old Tek 454 150MHz 'scope will have sufficient bandwidth to cope with the waveforms...
                      TELEFIX
                        No Z bias on this set.
                        Your scope is more than sufficient (I have used a 20MHz analog scope no problem, the maximum sustain frequency is around 200kHz.) But you must use a 10X probe.
                        • Alastair E
                          Chief Womble
                          • Mar 2013
                          • 1963
                          • U.K.
                          Cheers Tom, I didnt think there was any Zbias in this version--there's no DC/DC converter on the ZSUS board. As I said--There's not much apart from the IPM and a chip on there....
                          You reckon its still a 'zsus' board issue...?
                          There appears to be no panel 'priming' (Glow) at all....
                          Good to know the scope will be good, I have a couple of x10 probes so no probs there....
                          TELEFIX
                            No, without Zbias I am not sure.
                            This display is not even 720p capable, I'm surprised people still bother with repairing these.
                            • Alastair E
                              Chief Womble
                              • Mar 2013
                              • 1963
                              • U.K.
                              Ha!--Yes, Only doing it to gain experience on these things!
                              So--we have some (No!) Progress....
                              The voltages are all present and correct.
                              The ZSUS is outputting its square-wave and is in time with the YSUS 'frame' square-waves.
                              The 'Ramp waveform--Which is a bugger to trig on! is only half right.
                              The 'set-up' ramp and flat-top are correct and set to 10uS, as per manual--pot alters it normally.
                              There is No set-down ramp, it returns direct to base-line after the 10uS flat-top of the set-up ramp.
                              Adjusting the set-dwn pot just moves the ramp in relation to whatever the scope is triggering to.
                              This ramp waveform appears to be repeated twice--although are slightly different- before the 'frames'
                              Looks like this fault is on the YSUS. The IPM is mildly warm, the block of 10 MOSFETS under the heatsink are cold.
                              TELEFIX
                                Can I see a picture of these waveforms?
                                Z-sus should have a ramp too.
                                • Alastair E
                                  Chief Womble
                                  • Mar 2013
                                  • 1963
                                  • U.K.
                                  Here you go--Pic quality is crap and I'm not sure the timing from the top (ysus) to bottom (zsus) waveform is accurate--it shifts about with trig-sync of scope...
                                  TELEFIX
                                  • Alastair E
                                    Chief Womble
                                    • Mar 2013
                                    • 1963
                                    • U.K.
                                    BTW--There doesnt appear to be any ramps on zsus. Looks like I was hasty saying there was no set-dwn ramp--as I say, it was hard to trigger on these waves, took ages to get much sense outta my old scope...
                                    Looking at service-manual--there should be a square-wave directly under the ramp wave--which doesnt seem to be there I'll check its not the scope telling me lies...
                                    TELEFIX
                                    • Alastair E
                                      Chief Womble
                                      • Mar 2013
                                      • 1963
                                      • U.K.
                                      Now got to grips with the scope. Looks like the bottom ZSUS wave is Inverted to what it should be in the manual diagram--its not the scope doing it...
                                      Here you go--
                                      TELEFIX
                                        To get clearer shots of scope, try using sport or fast shutter mode on camera.
                                        I don't see why the waveforms would be different unless something is wrong with the control board.
                                        • HTR-Informatique
                                          by HTR-Informatique
                                          02-09-2025, 06:51 AM
                                        • VcemPzd
                                          Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                                          by VcemPzd
                                          Hello everyone !
                                          My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                                          04-28-2025, 10:14 AM
                                        • classypenguin
                                          Grundig 55 GUT 8768_55 (chassis gf) Black Screen, powers on and shows backlight
                                          by classypenguin
                                          Hello, I bought a Grundig 55 gut 8768_55 (chassis gf) as a defect ‘black screen.
                                          Now I have started with the basics:
                                          Fuse intact, LED Tester says 123V, BL Cap has 140V, Mainboard to PSU 12V, 24V, 3.3V and 5.2V are avail+able, 12V and 3.3V at TCON (TV has no seperate Tcon)
                                          As soon as I switch on the TV, it shows backlight, but a small grey line which disappears again.
                                          When I tap Menu, the background light becomes brighter. What can I assume is wrong with the TV?
                                          A defective mainboard? Or a software problem?
                                          I would be glad of help....
                                          09-21-2024, 01:07 PM
                                        • turmix
                                          AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                                          by turmix
                                          Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                                          The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                                          At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                                          During another reassembly, I made a mistake, and...
                                          01-29-2024, 03:48 AM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
