lg50pc1da
  • joe.90
    • Mar 2013
    • 6
    • wales
    lg50pc1da
    Hi hope that Tom66 can help with this problem
    Tv wont come out of standby
    No voltage at ac detect
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: lg50pc1da
    Post some clear pictures for him
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      Re: lg50pc1da
      Moved from FAQ.
      There are other experts besides tom66. Don't get me wrong, he's all 7 letters of awesome, but anybody who has a clue is welcome to toss $0.02... even newbies have soled problems the "regulars" have had no idea (alternate perspective?).
      As P4 said, could you post some pictures?
      sigpic
      (Insert witty quote here)
      • randtek
        • Oct 2011
        • 280
        • US
        Re: lg50pc1da
        Once you get the pictures posted, we can give you a test procedure to try to force the panel on. This can give some useful diagnostic information, based on how it behaves.
        • joe.90
          • Mar 2013
          • 6
          • wales
          Re: lg50pc1da
          SORRY Guy's may take some pictures tomorrow, but i know Tom66 has
          cured this problem
            Re: lg50pc1da
            I have cured it before on the 42PC1D; but the power supplies are completely different.
            • joe.90
              • Mar 2013
              • 6
              • wales
              Re: lg50pc1da
              Sorry mixed up two previous theads of yours,this video you made a link to is the exact problem on my tv
              http://www.youtube.com/watch?v=hOADH...ature=youtu.be
              Yes the power supplies are different my mistake
                Re: lg50pc1da
                Was a bad Y-sus and Y-buffer on that model in the end, it was determined uneconomical to repair. I don't have a brain the size of a planet (unlike Marvin) so I can't remember the places to make the modification. How's about a picture of your PSU so I can see where to bridge?
                • joe.90
                  • Mar 2013
                  • 6
                  • wales
                  Re: lg50pc1da
                  Thanks for the help will take pictures ASAP
                  • tvguy12012012120
                    by tvguy12012012120
                    02-07-2025, 05:13 PM
                  • fharris1977
                    Vizio D50u-D1 Dead Set No Standby
                    by fharris1977
                    Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                    12-28-2023, 10:25 AM
                  • Crystaleyes
                    Samsung BN44-00259A standby question
                    by Crystaleyes
                    Hi all.
                    I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
                    SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
                    Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
                    The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
                    08-11-2023, 05:15 AM
                  • psssst
                    Yamaha TSX 120 Standby Problem
                    by psssst
                    Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
                    03-01-2024, 07:25 AM
                  • ChristianBr01
                    LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                    by ChristianBr01
                    I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                    The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                    What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                    04-23-2025, 01:48 AM
