Vizio vx20l - no picture no sound powers on, cannot turn off
  • gorayomd
    • Mar 2013
    • 3
    I've seen similar type posts for similar issues/models, but not sure if all the recommendations would apply. I've checked out the main fuses and the regulators and they all seem to be ok. Any other tips or next things I should check?
    Thanks in advance and much appreciated
  • Dgtech
    E. Technician
    • Apr 2009
    • 1462
    • Steeler
    Re: Vizio vx20l - no picture no sound powers on, cannot turn off
    Check caps maybe... post pictures so we can inform you better what to check. I would say to check the inverter board but your tv might not have one. From the pictures...oh...wait... there are none.
      Please post good clear pictures of all the boards using attachment function so we can see what we are dealing with.
      • gorayomd
        • Mar 2013
        • 3
        Sorry about the pics in advance, the best I can do with my camera phone.
        Let me know if you need better pics of anything.
        • gorayomd
          • Mar 2013
          • 3
          Does anyone have the specs or should I list the vin and vout as well?
            For each regulator list all three pins (the fourth tab pin is the same as the second pin) plus the part # on the device.
            • csmith
              Vizio D50u-D1 Powers up no picture
              by csmith
              I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
              Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
              supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
              issue. Set will power up with remote but not power off....
              07-11-2025, 11:52 AM
            • ggil44
              Vizio M65-E0 No Picture, No Sound
              by ggil44
              Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
              09-03-2024, 08:30 PM
            • TR103
              by TR103
              - it keeps rebooting
              01-22-2025, 04:12 PM
            • Mgiffune
              by Mgiffune
              I have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started β€˜fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
              I ordered a supposedly β€˜new' Tcon board this time, and
              06-09-2024, 10:28 AM
