Lg 32ld350
  • Clucas
    • 26
    Lg 32ld350
    Hello, I have this LG with no Tuner function, ie No analogue or digital channels.
    I've tried a factory reset and scan and also shorted out the eprom on mainboard to reset it's data but no difference. There doesn't appear to be any smd fuses to replace and it only has one tuner so could it be the tuner, and has anybody had the fault and fixed it? Don't really want to replace the main board if possible.
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: Lg 32ld350
    Does it work with other inputs?
    Are all the supplies present from the PSU?
    TELEFIX
    • Clucas
      • 26
      Re: Lg 32ld350
      Yes and yes.
        Re: Lg 32ld350
        Check the +3.4V from PSU, if present.
        • Clucas
          • 26
          Re: Lg 32ld350
          Ya, has anybody actually seen b4? thanks for the replys.
          • Clucas
            • 26
            Re: Lg 32ld350
            LOl, obviously not. just a test lol.
            • rtstorm
              • Feb 2012
              • 971
              • Croatia
              Re: Lg 32ld350
              hello, i have the exact problem, All input ok only tuner cannot find any channal.
              Any ideas?
              ...the quieter you become the more you are able to hear...
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                Re: Lg 32ld350
                Is it set to Hotel Mode? Have you checked voltages on the tuner pins?
                • rtstorm
                  • Feb 2012
                  • 971
                  • Croatia
                  Re: Lg 32ld350
                  yes, it is set to Home use. On tuner pins i have 3.3V, 5V. I think all voltages is good.
                  Is it worth to replace tuner only? i found it on ebay for 28 USD
                  • rtstorm
                    • Feb 2012
                    • 971
                    • Croatia
                    Re: Lg 32ld350
                    i also try to flash new firmware, and reset to factory reset.
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      Re: Lg 32ld350
                      Is it going through the motion of scanning and finding channels but just not storing them or is it not finding any channels. If not finding any channels check your aerial connection. The last person who has a similar problem found that his aerial worked one set but not another set alongside. Different tuners have different gains, so a weak signal could viewed on one set with a high gain tuner but not on another set with a lower gain tuner.
                      • victor_cj
                        • May 2015
                        • 90
                        Re: Lg 32ld350
                        Try with this software from eeprom, 24HO1RP IC104, chassis LD01B.
                        24HO1RP is equivalent of AT24C1024.
                        LG 32LD350ZA 24HO1RP AT24C1024 IC104 LD01B.BIN https://www.xfile.ro/1VcMuFZ&p=RQ8Sm7vPY2KFXU6
                        The art of fighting without fighting
                        • rtstorm
                          • Feb 2012
                          • 971
                          • Croatia
                          Re: Lg 32ld350
                          TV scan but nothing found, no TV channel. I try on 2 places. On my home and my friend TV (and i have similar LG TV) i have signal 98% on my TV but when scanning with this TV no channel found.
                          • rtstorm
                            • Feb 2012
                            • 971
                            • Croatia
                            Re: Lg 32ld350
                            how can i flash it? do i need to desolder eeprom IC and flash it with programmator?
                            is the flash IC (MX-15G 25L8005M2I) 8 pin SOP.
                            • rtstorm
                              • Feb 2012
                              • 971
                              • Croatia
                              Re: Lg 32ld350
                              Sorry i did not read at first that you mean on IC104
                              • rtstorm
                                • Feb 2012
                                • 971
                                • Croatia
                                Re: Lg 32ld350
                                What is chassis LD01B? I have in my programator AT24C1024 IC but it failed process at 100%.
                                maybe my setup is wrong. I use TL866 universal programator
                                • rtstorm
                                  • Feb 2012
                                  • 971
                                  • Croatia
                                  Re: Lg 32ld350
                                  well i manage to flash the file you send me, but still no channel when scanning.
                                  • ReeceyBurger123
                                    Never Give Up !
                                    • May 2014
                                    • 7325
                                    • Britain
                                    Re: Lg 32ld350
                                    Resolder the tuner, add fresh solder to the contacts too for the ground and inside the port and the motherboard. Will upload youtube video of the repair soon.
                                    • rtstorm
                                      • Feb 2012
                                      • 971
                                      • Croatia
                                      Re: Lg 32ld350
                                      Ok will try that, hope to see video soon.
                                      • maxvalutech
                                        • Dec 2014
                                        • 804
                                        • australia
                                        Re: Lg 32ld350
                                        For clucas a quick fix would seem to be put a settop box in place as they only $20/30 now.
                                        • chth96
                                          by chth96
                                          03-09-2024, 10:03 PM
                                        • DXseekerMO
                                          Samsung PN51F8500AFXZA broke off the tuner's F connector, can't get tuner de-soldered
                                          by DXseekerMO
                                          I can hear Fred Sanford now...."YOU BIG DUMMY".....I pulled the "F" connector out of the tuner by accident. The tuner number is BN40-00248B. Low and behold I had a scrap board with tuner number BN40-00248A. Although the tuner is different (according to Encompass.com) it's footprint on the board is exactly the same as the 248B so I decided to de-solder the tuner off the scrap board to see what I was getting in to.
                                          As you can see in the picture the terminals and solder pads are super small. No matter what I tried I could not get either the terminals or support...
                                          09-15-2021, 05:15 PM
                                        • EvazX
                                          ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
                                          by EvazX
                                          I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
                                          Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
                                          For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
                                          However, after some time, the replacement motherboard...
                                          08-25-2025, 06:09 PM
                                        • odie34
                                          Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
                                          by odie34
                                          I am a hobbyist (not a professional) so please be gentle...
                                          I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
                                          I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
                                          02-18-2024, 09:11 AM
                                        • ictc
                                          Philips MDP 3380/12 Blu-ray Player – No Power, Reset Signal Always High
                                          by ictc
                                          I'm troubleshooting a Philips MDP 3380/12 Blu-ray player that shows no signs of life. The display remains off, and no buttons respond.
                                          Inside, the power supply is working correctly, and all expected voltages on the mainboard match the service manual specifications. The CPU warms up slightly (checked with a thermal camera), the crystal oscillator is functioning, but the reset signal remains high at all times.
                                          The reset circuit appears to consist of two NPN transistors, one driven by 5V VCC and the other by 3.3V STBY, as shown in the attached schematic. Should the reset...
                                          02-25-2025, 12:15 PM
