insignia ns-l42q-10a White Layer on Picture
  • shaggypeach
    • Mar 2013
    • 10
    Hello all...
    I do not know how to describe my problem well enough so I took couple of pictures. I also included some pictures of the boards and such. The board that the power cable goes into has been replaced with another one that was advertised as working however there was no change. I do not know what else to look for. Everything about the TV works. The only problem is the transparent white layer on top the picture as can be seen in the pictures.
    I was hoping you guys can help me out. Any other information regarding the problem, I will provide.
    B.T.W. I am a complete newbie - although I fix computers, I have not fixed any TVs yet. I'd appreciate if you guys can go easy with the terms (:
    Thank you !!!
    Re: insignia ns-l42q-10a White Layer on Picture
    Depends on your level of experience.
    The fault is the AS15-HF chip on the T-con -- the smaller square one.
    Replacing it isn't too difficult or expensive (chip is under $5) but requires moderate SMD soldering skills.
    The entire T-con may also be replaced too.
    • shaggypeach
      • Mar 2013
      • 10
      Wow that was amazing response time.
      I have soldered many things before. I will order one soon and see how it goes. Are any chain stores that will send this kind of thing? I prefer just go and get one.
      Thank you so much !!!
        Only places I know of are eBay. RadioShack and their cousins are too busy selling phones, from what I hear.
        • shaggypeach
          • Mar 2013
          • 10
          Thank you !
            Poster reports TV is now fixed by replacing that IC.
            • martyparish
              • Dec 2012
              • 313
              Good call Tom!
              • bug_nuts
                • Sep 2013
                • USA!
                I am having the exact same issue, I do not feel comfortable soldering on a new AS15 chip, so i was looking to replace the entire T-con board. I have the same T-con Board pictured by the OP, but when i do a google search i only seem to find a board that looks different
                http://www.ebay.com/itm/INSIGNIA-NS-...item1c35701c99
                http://www.shopjimmy.com/cmo-35-d033150-t-con-board.htm
                Both of those sites list the same model number as the TV i have, but like i said my t-con board looks like the OP's. The connections look the same,but there is a white connector on the left hand side that is not on my current tcon board.
                Will that board work? or where can I find the exact same board?
                • truep
                  • Aug 2010
                  • 373
                  See the white sticker on the board? That should have the part number on it. Type that into SJ or Ebay. Many TV's use different panels in the same PN.
                  • bug_nuts
                    • Sep 2013
                    • USA!
                    when i type in that number i do not get anything
                    I do find other boards online using the T420HW04 number on the bottom left of the board.
                    When i search Ebay with that number I find boards that look exactly the same, But none of them say they are from my model number TV. But I assume if it is the exact same board/ board model number. I should be fine?
                    For example:
                    http://www.ebay.com/itm/LG-42LH30-TC...item35cb831c2f
                    (also thank you for the fast response)
                    • chrisULM
                      • Jun 2014
                      I've got this exact model with the same problem. Did you somehow diagnose the AS15-HF chip by looking at the pictures OP attached or is this just a common repair for the "white layer" problem?
                      • jose6326
                        • May 2013
                        • 707
                        I wish the tv im working had that easy fix
                        • chrisULM
                          • Jun 2014
                          For example:
                          Just following up in case someone else with this same issue finds this thread.....
                          I picked up a T420HW04 board from a different model TV on ebay and it worked perfectly. If its the exact board and model number, it will work.
                          Thanks for the help guys. No more white layer and the tv looks good as new!
                          • slimbobaggins
                            • Feb 2012
                            • 6
                            Bumping this... my coworker's TV is having washed out and color issues, same model as in the title, and I suspect it's the same AS15-HF chip. I'm going to order a couple off of eBay tonight, and once I've got them and installed, I'll report back if that was the solution.
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              If the chip has a metal base which is soldered to the circuit board then it is a real pain to get off unless you have experience.
                              • slimbobaggins
                                • Feb 2012
                                • 6
                                Yeah I do electronics for a living so Im lucky enough to have access to the proper stuff.
                                • ryanfan03
                                  • Apr 2014
                                  • 45
                                  I don't mean to bring up an old thread, but my TV has this same thing. I ordered a new T-Con and it did not change. Is there a way to test the chip? I am at work and really have no idea if my t-con even has this chip.
                                  I might just start a new thread when I get back home.
                                  Doing this on the side to make some extra money for my daughters dance competition.
                                    Start a new thread and make sure to include make and model in the thread name, also upload good clear pictures of the T-CON so we can tell you where to the check the GAMMA Voltages on the T-CON bd.
                                    • slimbobaggins
                                      • Feb 2012
                                      • 6
                                      Necro bump. I forgot to update that I installed a new AS15-HF chip, and the TV was fine. Thanks for the info.
                                        MSI Prestige P65 8RF-456NL Creator White Notebook P Specification for Upgrade or Repair
                                        This specification for the MSI Prestige P65 8RF-456NL Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-456NL Creator White boardview and P65 8RF-456NL Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                        09-06-2024, 07:46 AM
                                        MSI Prestige P65 8RF-442 Creator White Notebook P Specification for Upgrade or Repair
                                        This specification for the MSI Prestige P65 8RF-442 Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-442 Creator White boardview and P65 8RF-442 Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                        09-06-2024, 07:29 AM
                                        MSI Prestige P65 8RF Creator White Notebook P Specification for Upgrade or Repair
                                        This specification for the MSI Prestige P65 8RF Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF Creator White boardview and P65 8RF Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                        09-06-2024, 07:25 AM
                                        MSI Prestige P65 8RF-457BE Creator White Notebook P Specification for Upgrade or Repair
                                        This specification for the MSI Prestige P65 8RF-457BE Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-457BE Creator White boardview and P65 8RF-457BE Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                        MSI Prestige P65 8RF-445ES Creator White Notebook P Specification for Upgrade or Repair
                                        This specification for the MSI Prestige P65 8RF-445ES Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-445ES Creator White boardview and P65 8RF-445ES Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
