Technika lcd42-207 wont stay on (even with new power board)
  • bubblychaz
    • Mar 2013
    • uk
    The problem started a while ago, The tv sometimes wouldnt turn on (from standby) or would turn on from anywhere from 5 minutes to an hour, We left the TV turned off and unplugged for a few months and then started using it again the other day, Both times it turned on for 45 minutes before going back to standby.
    After looking around the internet we got a new power board for it, Put the power board in (100% correctly wired up) and turned the tv on,it turned on for a second and went back to standby, so is now doing the same it did a year ago.
    What else could the issue be?
    Ive looked over the internet today and seen a fair bit about inverter boards, However if its the inverter board would the whole tv turn off?
    The company I got the power board from think it could be the main board? They did say they will happily refund/exchange any items brought with 30 days.. My issue is I dont want to have to keep on messing about ordering and returning.
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Technika lcd42-207 wont stay on (even with new power board)
    Do you have a multimeter and soldering equipment?
    Welcome to the forum-
    We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back (in the same orientation) and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
    Examples of what is needed
    https://www.badcaps.net/forum/attach...7&d=1280167246
    https://www.badcaps.net/forum/attach...6&d=1280167246
    https://www.badcaps.net/forum/attach...4&d=1280167246
    It will be useful if you can say a bit about yourself - skills tools etc.
    Decide which boards you are going to use then do pics.
    Normally if it is just an inverter fault the tv continues with sound and a very very dark picture
    but I guess it would depend on the severity of the fault
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • Hakuu
      by Hakuu
      Hi There,
      More Details
      TV Model - LG OLED77G1PUA
      07-12-2023, 02:37 PM
    • canadaboy25
      Panasonic TC-P54VT25 No image. A or D board?
      by canadaboy25
      I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
      I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
      01-17-2021, 01:06 AM
