I have a 50 inch, P50S601 that I am having problems with. In a nutshell, it appears to be in power protection. When powered on the display flashes then the power button goes from steady blue to a flashing blue (flashes 3x then of for 2 seconds then repeats). I have disconnected the YSUS and XSUS alternately and applying power per the Plasma TV troubleshooting steps with the same results. Voltages coming out of the PSU appear to be correct when reading at the output at CNPP5 (connector that have the voltages listed below it) Another indicator is that the fans do not come on upon power up.
Hitachi p50s601 possible power protection
Re: Hitachi p50s601 possible power protection
Service manuals:
http://www.tgohome.com/ServiceManual...&Search=Submit
(The second one isn't working for me -- I'll see if I can fix that at some point, if I have the original file.)Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
Well, just figured it out. It is definately on of the buffer boards for the YSUS. SDR-U was the culprit. Disconnected SDR-U and set powered up showing lower display only as expected. Plugged it back in to verify and viola! No power and blinking blue light! Now to locate a replacement that wont cost an arm or leg....Comment
They don't exist. That is, the failure is so common that the buffers regularly go for upwards of $200~$300. However, you can repair them yourself if you or a friend is handy with SMD.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
How do i go about getting a schematic of the card? Looking at it, there is nothing obvious.
There are test points TP1 thru TP8 even and odd.
Could the schem be on the document that is damaged that you directed me to?Comment
Received the new SDR-U today. Put it in the TV, powered up, and..... display flashed and saw good on lower but lines on upper half. 10 seconds later, poof! back in protection. URGGGH!!! When cycling the power, see the same thing so I believe that the SDR-U was only one of the issues. Now what? Back to the drawing board.Comment
Assuming...7 Photos -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
This specification for the HP Pavilion Power Pavilion Power 15-cb009nl Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 15-cb009nl boardview and Pavilion Power 15-cb009nl schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...09-06-2024, 05:59 AM
by navagatorI have a Hitachi 57F710E rear projection set with a bad power supply board. I've tried to fix it with help from this forum as well as another one, but without success. Today I found a Hitachi rear projection set for sale on Facebook that looked just like mine. After contacting the seller I found out it was a 51F510. According to the service manuals my set uses a HA01312, POWER UNIT DP4X-DM_24W and the 51F510 uses a HA01313, U901, POWER UNIT DP4X_24W.
Does anyone know if these 2 power supply boards are interchangeable?
Thanks.01-08-2024, 07:53 PM - Loading...
