Lg 37lf66-ze
  • ed1808
    • Mar 2013
    • 30
    • United Kingdom
    Lg 37lf66-ze
    power supply pn EAX31845201/13
    tv led flashes 5 times and powers up eventualy
    hi guys ok im trying to understand the measurments obtained via the esr60
    just so i dont keep boring you all with mindless post regarding dead or failing caps once again i have ordered a kit which should fix this problem for this cheap tv. but as i hope you understand the need to the readings im obtaining are a neccesity.
    i have added the readings list of all the caps i have tested (in curcuit/2 out) via the esr60
    so any help with the tollerence of both esr and capacitance value of these readings would be appreciated.
    please excuse my spelling and grammer in general lol
    if you need the manufacturer and code of each cap thats no problem but im sure in all you guys can tell a bad cap via its reading and thats where i need to be in general
    c223 as fitted 680uf 35v in circuit leaky 0.00 ohm cap taken out reading 722uf 0.02ohm
    C221 as fitted 680uf 35v in circuit leaky 0.00 ohm
    C222 as fitted 680uf 35v in circuit leaky 0.00 ohm
    C232 as fitted 680uf 35v in circuit leaky 0.00 ohm
    C203 as fitted 470uf 35v in circuit leaky 0.22 ohm cap taken out reading 427uf 0.26ohm
    C207 as fitted 1000uf 35v 1470uf 0.00ohm
    C208 as fitted 470uf 35v 1770uf 0.14ohm
    C212 as fitted 2200uf 25v 2556uf 0.02ohm
    C216 as fitted 2200uf 16v 2549uf 0.00ohm
    C213 as fitted 470uf 25v 2502uf 0.08ohm
    C225 as fitted 2200uf 10v 3013uf 0.03ohm
    C205 as fitted 3300uf 10v 7829uf 0.01ohm
    C204 as fitted 3300uf 10v in circuit leaky 0.00ohm
    many thanks in advance
  • selldoor
    Slow Learner
    • 7870
    Re: Lg 37lf66-ze
    Not sure what the question is - if you have ordered a cap kit to fix it why
    test the caps? does leaky mean its leaking electrolyte if so dispose of it at once.
    • ed1808
      • Mar 2013
      • 30
      • United Kingdom
      Re: Lg 37lf66-ze
      no sorry none of the caps are leaking to look at or bulging.
      just trying to understand the readings the esr60 is giving me
      kits are fine in the long run guess for instance c205 is reading 7829uf which is huge yet is only 0.01 ohms and the top 4 are reading in curcuit leaky yet on removng 1 i get a normalish reading.
      maybe its just me but as i said im just trying to interprit the readings im getting so as to understand the values
      • cliff_hootarski
        • Jul 2006
        • 411
        Re: Lg 37lf66-ze
        You must test these caps out of circuit to get an accurate reading. Some of those caps could be in parallel with each other, so one cap could be good and the other bad.
        I have the ESR70 and when ever I test "in circuit" and get a bad reading (either capacitance or ESR), I pull the cap and test "out of circuit".
        • ed1808
          • Mar 2013
          • 30
          • United Kingdom
          Re: Lg 37lf66-ze
          many thanks cliff purchased the esr60 to save time really but get your point will pull all the caps and retest
          • ed1808
            • Mar 2013
            • 30
            • United Kingdom
            Re: Lg 37lf66-ze
            ok chaps replaced all the bad caps on the power supply and tested voltages all seemed good tv powered up for around 30 mins lol then the screen started flickering... so tried all inputs al are the same but i now have no sound via the hdmi either any ideas please many thanks
            • Alimash
              op amp circuit function?
              by Alimash
              I am repairing a ups which doesn't turn on ,it has the following ICs:
              SG3525 used to drive inverter mosfets.
              couple of uc3483, one for the power supply and another to drive a big mosfet at the output stage(i think the technique is called boost)
              A LM358 and TL074 for control mechanism and of course the uController.
              The SG3525 is shutting down every time the ups is turned on.
              I want your help to know the function of LM358 and TL074 in the system.
              I reverse engineered the LM358 circuit and i think that one of the block(A) is used for battery level...
              07-31-2025, 07:45 AM
            • Astonished
              Fixing the Charge Circuit of the Batteries of the DC Motor
              by Astonished
              Hi friends of electronics
              What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
              The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
              Please help me fix this circuit.
              (the datasheet of the IC: https://pdf.datasheet.live/28...
              01-28-2025, 06:24 AM
            • rddube
              Lenovo L490 Ram voltage circuit malfunction
              by rddube
              Hello friends,
              Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
              I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I...
              07-15-2025, 04:41 PM
            • Tarot Superstars
              Short Circuit tester
              by Tarot Superstars
              Hello.
              I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
              The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
              Link
              The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
              https://www.youtube.com/watch?v=0eixDdCpiO4
              My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
              09-25-2023, 09:11 AM
            • M1NEBLANK SHOW
              MSI B250 Gaming M3 Short circuit in CPU power supply circuit
              by M1NEBLANK SHOW
              Hello. MSI B250 Gaming M3 board, short-circuit on the power supply. Found a problematic mosfet VQ1
              (N-PK616BA_PDFN8-HF) soldered it out - short circuit is gone. I replaced VQ1 + VQ5 (N-PK632BA_PDFN8-HF). VQ1 was replaced with PK618. After starting attempt VQ1 is lit again. What can be the problem? In the driver?
              Schematic and Boardview here
              04-04-2025, 03:57 PM
