Vizio 26" VW26L Flickering white screen
    Re: Vizio 26" VW26L Flickering white screen
    Yes.
    Missing a digit can change conclusions very significantly.
    • CR Designs
      • Dec 2012
      • 430
      Tom66, I pulled caps off the PSB there are 2 caps that are 2200 10v and they are measuring 2670 is that to high. Are they O.K
        They sound fine, and besides, would be unlikely to cause the fault.
        • harp
          White screen repairs
          by harp
          To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
          Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
          On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
          05-13-2024, 03:43 AM
        • domu
          Viewsonic VS16217 strange problem - white flickering screen on power up
          by domu
          As per subject, on power up display shows no image, but white
          flickering screen. Strangely, it only happen after power was lost
          when it was on. After power returns - white screen only, but if
          disconnect power for 12-24 hrs, and connect then again monitor
          works normally.
          Any clues how to go about it would be greatly appreciated.
          07-18-2023, 04:57 AM
        • spice_disc
          Vizio TV M50-C1 reboot cycle and static on screen
          by spice_disc
          I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
          The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
          09-08-2024, 02:37 PM
        • Ado02
          Lenovo Thinkpad X1 Gen 10 - Flickering Screen
          by Ado02
          We recently replaced the OLED screen on a Lenovo ThinkPad X1 Gen 10. After about a month, the replacement screen began to flicker. Initially, updating the Intelยฎ Irisยฎ Xe graphics driver resolved the issue for about a week. However, when the problem recurred, updating the driver again had no effect.
          The flickering only occurs once the system reaches the Windows login screen. Interestingly, if we disable the Intel GPU driver or connect the laptop to an external monitor, the flickering stops. We have tried installing two different replacement screens,...
          12-16-2024, 02:33 PM
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
