Darn need help guys samsung ln-t4042h 24v backlight problems
  • davewilson61
    • 110
    • usa
    HI GUYS
    SAMSUNG LNT4042H
    Plug in relay clicks waits 10 seconds clicks again every 10 seconds led on front blinks 5 time
    found 1 bad cap but changed 7 of the larger caps by the bad one
    check all voltages seem to have them 5v 12v ect
    only one never present at any clicks is the 24v for the backlight inverter even unpluged the board from the ps and still no 24v on the ps connector.. stays at 0v ....
    i guess the tv is cycling over and over looking for the backlight to come on..
    cant find the 24v section on the schematic ? strange...ELEktro or tgohome
    thanks if you can help ...dave ...can have pics up in 10 min if needed
    Re: Darn need help guys samsung ln-t4042h 24v backlight problems
    What capacitors did you use as replacements?
    • davewilson61
      • 110
      • usa
      nte the bad one and 6 others
      • notallbad
        • Oct 2012
        • 1190
        Not familiar with the set and no schematics provided so is there a pin marked BL_On? Normally reads around 3v. This is the signal which returns to the PS to provide the 24v for the inverter.
        • davewilson61
          • 110
          • usa
          some picks
          • notallbad
            • Oct 2012
            • 1190
            Any voltage on Pin 1 at CN1803?
            • davewilson61
              • 110
              • usa
              iteresting above cn1803 it says inverter on/off above the 7 capasitors i replaced
              maybe the main board is not turning on the inverter...wonder if i could jump it..guess i could check it for volts...powered on and off ?
              • davewilson61
                • 110
                • usa
                would that bl be inverter on/off pin...ill check for the bl ....be right back
                • notallbad
                  • Oct 2012
                  • 1190
                  BL_On - Back Light On
                  It may be that on power up the PS provides 24v to the inverter, the inverter then powers up and sends the 3v BL_On (Inverter On) signal to the Main board.
                  • notallbad
                    • Oct 2012
                    • 1190
                    Get some really good close up images of both sides of the PS board.
                    Look for any dry joints on the solder side of the board too! Especially around the Transformers.
                    • davewilson61
                      • 110
                      • usa
                      ok cn1803
                      1 0.02v relay goes off and on no change
                      2 3.34v
                      3 0v
                      4 0v
                      5 5.38
                      • davewilson61
                        • 110
                        • usa
                        getting them close ups
                        • davewilson61
                          • 110
                          • usa
                          pics up...cant find anything BL
                          • davewilson61
                            • 110
                            • usa
                            did check the inverter for power up dead 0v always not even a spike in volts
                            • davewilson61
                              • 110
                              • usa
                              think i should jump 5v to pin 1?
                                Pin 1 is PSON?
                                On some Samsung it is supposed to be low to turn on.
                                • notallbad
                                  • Oct 2012
                                  • 1190
                                  Is that Pin 1 CN?01 Power On/Off?
                                  • davewilson61
                                    • 110
                                    • usa
                                    cn1803 inverter on/off... its at 0.02v always add 5v? would turn on backlight no?
                                    • davewilson61
                                      • 110
                                      • usa
                                      pin 1
                                      • notallbad
                                        • Oct 2012
                                        • 1190
                                        Yes, that would prove the PS is alright if the inverter kicks in with 24v supply and that the inverter board is good if it gives a 3v Inverter On signal.
                                        So fault will be with the Main A/Vboard.
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
