Darn need help guys samsung ln-t4042h 24v backlight problems
  • davewilson61
    • 110
    • usa
    Re: Darn need help guys samsung ln-t4042h 24v backlight problems
    ok lets try it .....brb
    • notallbad
      • Oct 2012
      • 1183
      Originally posted by davewilson61
      cn1803 inverter on/off... its at 0.02v always add 5v? would turn on backlight no?
      I think the Inverter On Signal comes from the inverter to tell the Main board that the inverter is on and all is well, so do not put 5v on that pin.
      • notallbad
        • Oct 2012
        • 1183
        Don't confuse the two CN's and signals we are talking about.
        Lets first confirm which CN - Connector and which Pin we are discussing.
        • notallbad
          • Oct 2012
          • 1183
          With TV switched on but in standby check the voltages at all the Connectors and list the results.
          Then do the same with the TV on, or at least attempting to come on.
          This may be time consuming but worth the effort.
          • davewilson61
            • 110
            • usa
            guess what we have backlight but nothing on the screen it just lite
            • davewilson61
              • 110
              • usa
              #26
              with 5v to cn1803 pin 1
              • notallbad
                • Oct 2012
                • 1183
                How did you get the back light to come on?
                CN803Pin 1 Power on / off
                Picture 7 in Post 13 Top left corner of solder side of PS board.
                • notallbad
                  • Oct 2012
                  • 1183
                  OK, so PS 24v supply is good.
                  Check voltages as mentioned before in stby and trying to come on.
                  It is looking though the fault lies with the Main A/V board.
                  • davewilson61
                    • 110
                    • usa
                    #29
                    thinks so.... ok ill order one
                    thanks beer and pizza for you guys...but the pizza mybe cold coming form this far....lol
                    • notallbad
                      • Oct 2012
                      • 1183
                      Are you turning on the Tv with a remote or the side panel buttons?
                      • notallbad
                        • Oct 2012
                        • 1183
                        Further checks need to be made before ordering anything.
                        Not yet concluded that the fault lies with the Main A/V board.
                        • davewilson61
                          • 110
                          • usa
                          #32
                          front on button on tv..... should i use the remote
                          • davewilson61
                            • 110
                            • usa
                            #33
                            ok its a 24 pin connector..ill get the volts with tv stand by and on ...brb in about 15 min
                              PS_ON (Power supply ON to turn on the 12v and 24v POWER SUPPLY), BL_ON (INV_ON) is the signal for turning on the PWM circuits of the Inverter board (the inverter needs 24v to run), Dim (or PWM) is for lamp brightness control. All those signals are generated by the Main board, the signals are routed through the power supply board (for clean wiring lay out).
                              So you need to find out for sure if you do have all those 3 signals from the Main board.
                              • notallbad
                                • Oct 2012
                                • 1183
                                Might be worth chcking it also works from the remote and check to see if the other function buttons on side/front panel and remote work, though of course with no picture you will be limited as to which functions you can confirm work. The IR LED flashing doesn't really confirm that the function is actually working.
                                • davewilson61
                                  • 110
                                  • usa
                                  #36
                                  got this ....relay clicks backlight on.. got all listed volts per pins on cn801 5v 12v 13v
                                  ok relay off backlight off v drops to 0v on 12v 13v but stb 5v stays at 5v guess all is good on ps no?
                                    So right now the backlights are on when you turn on the TV and it stays like that with Glowing screen but no picture?
                                    • davewilson61
                                      • 110
                                      • usa
                                      #38
                                      i would have to unplug it for 30 mins to get it in stand by mode...but when i plug it in now 1 clicks backlight on...in 10 sec the relay clicks backlight goes off for 3 sec... relay clicks backlight on again for 10 sec ....follows this cycle over and over till unplugged
                                      • davewilson61
                                        • 110
                                        • usa
                                        #39
                                        when backlight if off no 12v 13v...but has stb 5v
                                        backlight on have 12v 13v
                                        but no 5v on pin 1 of cn1803 just my jumper
                                        • notallbad
                                          • Oct 2012
                                          • 1183
                                          Did you power off the tv or did it switch itself off?
                                          Ok ignore that.
                                          With your 5v jumper you are forcing the bl on, remove your 5v jumper and put it back as it should be.
                                          Is there no 5v on pin 1?
                                          Testing needs to be made on the main a/v board.
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
