Magnavox 50MF231d 37 Blown Fuse/supposedly solid green light when turned on
  • garry7263
    • Feb 2013
    • 105
    Re: Magnavox 50MF231d 37 Blown Fuse/supposedly solid green light when turned on
    I pulled out the Ysus board and checked the cap the kid put in, what a mess
      Oh dear ... wow. I'd be amazed if that works at all. Remove all of the solder and resolder it.
      • garry7263
        • Feb 2013
        • 105
        I pulled it out but unfortunately i only have the other capacitors that the guy gave me. The copper pad on that side was missing, which I guess her thought he could just solder the two leads together. I soldered the one leg to the other side if the board as that where it should connect to. Here is a pic of the repair.
          That should work.
          Next, see my previous tests:-
          Vs is much too low. Please set this carefully to the panel rating (+/-1V)
          Ve, Vset and Vsc are also very wrong, and will need to be set within +/-2V.
          Check in a dark room: does the plasma panel glow slightly?
          • garry7263
            • Feb 2013
            • 105
            it wasn't working at all. There is some discoloration to the back of the board and I checked the row of chips and they all tested just about exactly the same. I will install it and check to see if anything comes up.
            Tom, Should I adjust the voltages after putting the board back in, or should they be adjusted before I connect the X and Y boards?
              They should be adjusted with all boards installed.
              • garry7263
                • Feb 2013
                • 105
                Boards installed, unit clicks twice then once. Then everything shuts down and I lose all voltages. There is a green LED that starts flashing 5 times.
                The top most board is encased in metal and has two solid green LEDs inside.
                the board under that has two LEDs, the LED closest to the connector glows solid, but there is another LED under the AC in that flashes constantly.
                If either the X or Y boards are disconnected, the power does not shut down. The LED on the power board glows solid. I kind of lean towards the X and Y board being ok. I think that when both boards are connected, it draws too much current and shuts itself off due to some component not being able to handle the current.
                • garry7263
                  • Feb 2013
                  • 105
                  Come to think of it, that is probably why the voltages were so far off from where they should be.
                  • garry7263
                    • Feb 2013
                    • 105
                    I am off to get parts to make an ESR meter today. I think I will go through power board component by component.
                    • garry7263
                      • Feb 2013
                      • 105
                      I had to put this away for a while. I am just getting back to it. I went through the Y-sus and found two rows of diodes shot near the black connectors. Also found the other cap near the replaced one was on its way out as it now shows a bulged top.
                      I ended up getting another Y-sus board and checked those diodes and they measure good. I dont want to put in a new board and kill it, so I need to know how to check for a bad Y-buffer.
                      Before, it would turn on and then shut down right away. Unplugging either the X or Y board would allow the power to stay on. Should I be looking at replacing the X-sus also ?
                      • garry7263
                        • Feb 2013
                        • 105
                        This is what I found when going through this board so I got a replacement
                        that is .001 VDC in diode mode
                        • garry7263
                          • Feb 2013
                          • 105
                          I need to know how to test the buffers to make sure they will not destroy the new board. Can anyone show me what pins I need to test and the best way. I think Coppel had a blog, but he says to test in diode mode but comes with an ohm reading and that doesn't make sense to be since ohms is resistance and diode test the flow of current. I have a Fluke 79iii
                          I have tested from a ground by the blue caps, get readings in the 4.7Mohm range on all the connector leads that go to the panel
                          I just want to make sure I don't kill the new Y-main and I do not have a lot of cash to replace it again but I might be able to scrounge up enough to get some new buffers
                          • corrize
                            A funny fuse story – Lumix LX100 II
                            by corrize
                            Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                            I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                            The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                            There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                            And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                            10-19-2023, 09:58 AM
                          • jesterace
                            Samsung UE46ES8000 Blown fuse but no other signs of short
                            by jesterace
                            Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                            09-11-2024, 03:14 PM
                          • jshhh
                            Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                            by jshhh
                            Hi guys,
                            I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                            How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                            Anybody know how to remove this type of fuse?
                            (The fuse is toward the bottom of the image labeled F2)...
                            06-17-2025, 01:35 AM
                          • Babbar
                            by Babbar
                            04-12-2024, 01:12 AM
                          • drykid
                            Matsui 175S microwave fuse replacement
                            by drykid
                            I recently picked up a used Matsui 175S microwave that was powering up (starts, turntable rotates) but not heating. From looking online the most likely culprit was the fuse, but unfortunately in this one the fuse had heated up and fused with the (badly designed) fuse holder and couldn't be removed. I guess this might indicate further issues beyond the fuse itself but at this stage I just want to replace the fuse and see how I go from there.
                            Anyway since I couldn't get out the fuse itself the easiest fix was to replace the fuse holder assembly that runs between the...
                            12-21-2020, 01:15 PM
