Faulty Samsung LE26R87BD, is it repairable ?
  • Mikeyboy2007
    • Mar 2013
    • 745
    • Scotland
    ok so i got another TV today that was nearly on its way to the dump... the problem is whats in the video, tv when switched on makes a crackling noise from speaker i assume, sometime doesnt come on when coming out of standby but when it does the picture is all messed up > have attached a video to show the best i can will upload some pictures of the boards also but there doesnt seem to be any bad caps
    http://www.youtube.com/watch?v=aKixo...ature=youtu.be
    Re: Faulty Samsung LE26R87BD, is it repairable ?
    I would first check if the power supply rails are good.
    • Mikeyboy2007
      • Mar 2013
      • 745
      • Scotland
      how would i go about doing that Tom66 ? Noob at this kinda stuff
        Check each voltage on each pin and compare to the labels.
        Red probe on each pin, black on case.
        • Mikeyboy2007
          • Mar 2013
          • 745
          • Scotland
          ok mate will check back with results
          • Mikeyboy2007
            • Mar 2013
            • 745
            • Scotland
            what voltage will i set multimeter to ?
              20VDC or if it goes to "1", 200VDC.
              • Mikeyboy2007
                • Mar 2013
                • 745
                • Scotland
                am i doing this with the cables plugged in and tv powered on as the readings are dropping as the tv keeps going back into standby then rebooting
                  Measure while the TV is running, if it stops, pause measuring then resume when it starts "working" again.
                  • Mikeyboy2007
                    • Mar 2013
                    • 745
                    • Scotland
                    ok will give it a pop and update you.. may be a while as tv is switching on and off by itself lol
                    • anotherdude
                      • Feb 2013
                      • 488
                      seems similar to the samsung i'm having problems with, get the crackle from the speaker the reboots and the distorted video
                      i found it's a problem with the av board, if i gave it some heat with a hair dryer towards the top it'd clear up pretty quick, maybe not be the same here but there both the same model LE32R87BDX just mines the 32"
                      • Mikeyboy2007
                        • Mar 2013
                        • 745
                        • Scotland
                        Tom66 just to update you, i was half way through doing the pins there and tv has stayed on for a few minutes and turned it round and was faced with a picture on the screen, fuzzy though i have attached a picture if it helps but will post results of pins as soon as im done
                        • Mikeyboy2007
                          • Mar 2013
                          • 745
                          • Scotland
                          yeah mate mines has a crackling coming from the speakers too and when it was booting i was getting distorted video
                          • Mikeyboy2007
                            • Mar 2013
                            • 745
                            • Scotland
                            ok there are 2 leads going to mainboard, after i posted that picture and finished the pins the picture has got clear and the AV board is realy warm at the top but picture isnt fuzzing anymore... so think its down to AV board Tom66 ?? is it repairable or will i need to buy new board altogether
                            Mainboard lead 1
                            1 on/off 5.03V
                            2 A/D 0.21V
                            3 P/D 5.70V
                            4 GND 0.00V
                            5 24V DET 5.40V
                            Mainboard Lead 2 (24 pin)
                            1 on/off 3.38v
                            2 n/c 0v
                            3 st-by 5.21
                            4 s-gnd 0v
                            5 gnd 0v
                            6 gnd 0v
                            7 12v 12.17v
                            8 12v 12.17v
                            9 gnd 0v
                            10 gnd 0v
                            11 gnd 0v
                            12 gnd 0v
                            13 5.3v 5.29v
                            14 5.3v 5.29v
                            15 5.3v 5.29v
                            16 5.3v 5.29v
                            17 gnd 0v
                            18 gnd 0v
                            19 13v 12.81v
                            20 gnd 0v
                            21 13v 12.81v
                            22 13v 12.81v
                            23 N/C 0v
                            24 N/C 0v
                            • anotherdude
                              • Feb 2013
                              • 488
                              exactly the same as min, if you change the input the fuzzy text fixes itself
                              found no solution for mine as of yet
                                The rails appear OK.
                                I would switch off the TV and cool it down.
                                Then heat up parts of the main board -- hairdryer and cardboard tube is one option.
                                When you find heating a part improves it, turn the set off, and repeat the test.
                                • Mikeyboy2007
                                  • Mar 2013
                                  • 745
                                  • Scotland
                                  ive done that a few times now and same results every time... is there a way to repair the board or would i have to purchase a new one
                                  • anotherdude
                                    • Feb 2013
                                    • 488
                                    from what i can gather it's needs a reball on one of the bga chips, pretty sure it's the top one
                                    reball can be expensive but so can a new board
                                    • Mikeyboy2007
                                      • Mar 2013
                                      • 745
                                      • Scotland
                                      my mate has a reballer.. will have a word with him see if hes up to the challenge
                                        No good without the reball mask I thought? Different for each chip and unlikely to be available for a Samsung LCD TV board. Lots available for Xbox etc!
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
