Long backorder on Panny plasma parts - anyone else?
  • bp61
    • Mar 2013
    • usa
    My Panasonic plasma 55GT30 got the 7 blinks. Since I was still under credit card extended warranty, I called a local service shop and they identified the SC board (TXNSC1NVUU) as bad. That was on Jan 30. They said it would be 2-3 weeks on back order. Later, they said it would be March 8th. They've now called Panasonic again at my request and Panasonic is saying another 3 weeks minimum!!
    Anybody else having this long of backorder?
    Is it know what is the cause of the backorder? Are they actually fixing a design problem and having new boards made? Or, do they plain just don't care about existing owners so they ship some boards when they get around to it?
    thanks
    Re: Long backorder on Panny plasma parts - anyone else?
    Very common issue with this set with 6/7 blinks (along with 20, 24 and 25 series.) My guess is Panasonic aren't producing enough to meet demand. Lots of people have the same issue.
    • bp61
      • Mar 2013
      • usa
      I considered the supply/demand issue, too, but being an 8 week back order is ridiculous. Almost makes it sound like they completely ran out of their warehoused supply of boards and are having to fire up a new production run to restock.
      Anybody talk to Panasonic directly yet to get more specific info?
      • rayrod81
        • Oct 2010
        • 205
        TV manufacturers do not make an endless supply of parts for newer TVs and since the plasma panels are made as a unit (Panel, SC Board, SS Board, and Buffers) they rarely make "extra parts". While they will generally keep enough parts on hand to cover repairs during the manufacturer warranty period once that is passed they will not keep building new parts. Most boards the repair shops sell and receive after warranty are refurbished from the company or are harvested parts sold by other companies. Backorders of 8 weeks is not unusual if the TV is out of warranty especially if it turns out to be a common issue on certain models. There are many TVs that parts are almost impossible to come by because they are way out of warranty and the problem arose after the warranty period ended. Even though you have an extended warranty it is the responsibility of your credit card company to fix your TV and not Panasonic. Many times when a TV fails the extended warranty coverage usually will just replace the TV because it will cost them as much or more to repair the customers TV.
        • szreder6
          HP Pavilion 14-ce0505sa, 5 long 3 short, no display. g7a-2g da0g7ambd1
          by szreder6
          Hello guys,
          I have a problem with my laptop as in the title, black screen, capslock displays error code 5 long 3 short, no voltage on the coils above the CPU, before removing the drive I had 0.8v there, power led flashed 5x long and the battery would not charge (current jumped from 0.5a to 2.8a), now on the power led I have a steady white light or orange when the battery is connected.
          What I did:
          - Laptop was not detecting ram, loose pins on ram slot, error 3.2 disappeared, ram working tested in another laptop
          As far as I know the laptop was in another service center...
          11-22-2024, 05:17 PM
        • ArMaaN376
          Samsung PS51E550 Plasma TV
          by ArMaaN376
          I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
          Opened TV cover & observed foll
          a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
          b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
          c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
          How to confirm Y -Buffer board...
          06-19-2024, 04:05 AM
        • jm1234
          Panasonic plasma TX-P42ST50 - 6 blinks
          by jm1234
          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
          I checked that board for any obvious faults...
          05-22-2024, 06:59 AM
        • chazh
          LG 60PS11-UA 60-inch 1080p Plasma TV-service lit & video help needed
          by chazh
          This is my first posting, so forgive me everyone in advance if I made mistake(s) in my posting.
          I know there have been much about this plama tv already and I have read through most what I could find. However; I still have not come across any service lit/schematics for this tv. I even looked for the 50PS11 which would be basically relevant other than display size. Anyone know to find the documentation would greatly be appreciated.
          The set that I have has issues with lower third of screen being dimmer than the above portion. From my past experiences with tube, solid state,...
          09-01-2025, 08:56 PM
        • porfyriadhs
          Samsung Plasma PS51D6900DS Bootloop
          by porfyriadhs
          Hello . I have a problem with a samsung plasma tv stuck in bootloop . The TV is Samsung PS51D6900DS plasma smart tv .Need help if anyone have any suggestions
          Thanks a lot !!
          10-19-2023, 11:31 AM
