Bush LCD37TV016HD
+ More Options
Posts
  • LEEDASH
    • Dec 2012
    • 481
    • Bedfordshire
    #81
    Re: Bush LCD37TV016HD
    Pin 1,2 and 4 nothing MULTIMETER dont even move.
    • Radio Fox
      • Jan 2010
      • 281
      Just thought that it may have a surge protection (inrush current) thermister in line, but even so, it should show some reading on the meter's 200 Ohm range.
      Can you just double check once more that pin 2 of the rectifier doesn't read anything when the other probe is connected to either the Live or Neutral of the mains plug. As before, if the TV has a mains switch, make sure it is in the ON position.
      ________________________________________________
      Invisible airwaves crackle with life
      Bright antennae bristle with the energy
      • LEEDASH
        • Dec 2012
        • 481
        • Bedfordshire
        #83
        Yes double checked all still the same only pin 3 showin any sign of life.
        • Radio Fox
          • Jan 2010
          • 281
          Hmmm...that doesn't seem right.
          On the attached photo I have put red & blue numbers. With your meter on the 200 Ohm range place the probes between blue 1 - 2, then 2 - 3, then 3 - 4, then 4 - 5. There should be almost zero Ohms between each.
          Do the same for the red numbers.
          • LEEDASH
            • Dec 2012
            • 481
            • Bedfordshire
            #85
            blue 1+2 00.4
            2+3 00.5
            3+4 00.8
            4+5 00.5
            red 1+2 00.4
            2+3 00.5
            3+4 00.4
            • selldoor
              Slow Learner
              • 7870
              #86
              Check the solder on Pin1 (Blue) I suspect the connector is not soldered correctly.
              • LEEDASH
                • Dec 2012
                • 481
                • Bedfordshire
                #87
                Seems ok pin 1
                • Radio Fox
                  • Jan 2010
                  • 281
                  So the open circuit is not on the actual PSU board (assuming there are no intermittent dry joints).
                  Does the mains lead go to another board before going to the PSU board? Is there a mains ON/OFF switch on the TV?
                  I know you have said that you have tried different mains leads, but could you test the fuse in the one you are using at the moment with your meter.
                  If you could attach a photo of the route that the mains lead takes, between the kettle socket and the input to the PSU board, that would help.
                  • LEEDASH
                    • Dec 2012
                    • 481
                    • Bedfordshire
                    #89
                    Ok the kettle lead socket lead (blue and brown) runs under (pic 2) then straight in to pic 1 ( the psu )
                    what shall i test the fuse on ?
                    • LEEDASH
                      • Dec 2012
                      • 481
                      • Bedfordshire
                      #90
                      no does not go to another board before the psu
                      • LEEDASH
                        • Dec 2012
                        • 481
                        • Bedfordshire
                        #91
                        00.5 testing on 200 ohms have tried lead in other tv and ok.
                        • selldoor
                          Slow Learner
                          • 7870
                          #92
                          Radio Fox prbably wants to see the socket where the kettle lead plugs into, that is, the other end of the blue and brown cable.
                          Well I Do
                          • selldoor
                            Slow Learner
                            • 7870
                            #93
                            Does the brown and blue connector unplug from the power supply board.
                            Check there are two pins in there
                            • LEEDASH
                              • Dec 2012
                              • 481
                              • Bedfordshire
                              #94
                              Yes you have the on/off switch next to it the glass fuse then the 3pin where the kettle lead goes into,yes there is a 2 pin on the pcb
                              • Radio Fox
                                • Jan 2010
                                • 281
                                I'm getting a bit confused now. Are you saying that there is another fuse before the mains supply reaches the PSU board?
                                We are trying to determine the path that the mains wiring takes from the kettle socket to the PSU board. If there is another fuse in the circuit that you haven't tested, put your meter across that.
                                Also it could possibly be a broken mains switch. If you can get to the contacts on the switch (they may be covered in heat shrink) then check that out with your meter. It should show nearly zero Ohms in one switch position & open circuit in the other.
                                As selldoor said, if it's possible, a photo of the path that the mains wiring takes from the kettle connector to the PSU board would be helpfull.
                                • LEEDASH
                                  • Dec 2012
                                  • 481
                                  • Bedfordshire
                                  #96
                                  we have obviously the plug fuse,that seems ok
                                  we have a 250v glass fuse next to where the kettle lead goes into,that is also ok,having changed this.
                                  i did post a picture couple above this
                                  Right how shall i test this on off switch at the back ? unit on or off or off in the on position ?
                                  • selldoor
                                    Slow Learner
                                    • 7870
                                    #97
                                    It depends on whether you can see any contacts on the switch- I suggest you use ohms
                                    200 and NO POWER. What I have in mind is to get a piece of wire or a paper clip - something to connect the positive and negative pins on the mains plug.
                                    Un plug the blue and brown socket at the power supply and connect your meter across the two pins then operate the on off switch.
                                    • LEEDASH
                                      • Dec 2012
                                      • 481
                                      • Bedfordshire
                                      #98
                                      Just disconnected the blue/brown form pcb,attached my multimeter to the wire/block,switched on/off and nothing dont even move.
                                      • LEEDASH
                                        • Dec 2012
                                        • 481
                                        • Bedfordshire
                                        #99
                                        do you think its worth changing the rocker switch ?
                                        • selldoor
                                          Slow Learner
                                          • 7870
                                          #100
                                          You need to have the kettlelead plugged into the kettle conector - but not into the mains AND short/wire across the mains plug as in the diagram, to complete the circuit.
                                          • jdawg99
                                            Bush DLED32287HDCNTDFVP - Is this a screen fault or a Tcon Issue
                                            by jdawg99
                                            Trying to fix a bush TV. The Tcon is integrated onto the main board by the looks of it but before I buy a replacement does this look like a screen fault? The lines at the bottom are concerning me. I have check for shorts on the caps etc and can't see anything obvious. Nothing is overly hot and I've tried heating different boards and pressing down on the flex but no change in picture.
                                            Any advice welcome. Thanks in advance....
                                            09-18-2022, 05:30 AM
                                          • Rictech
                                            Panasonic SA-MAX770PU SMPSU board fault....
                                            by Rictech
                                            Hello everyone. 😀
                                            As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                                            Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                                            Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                                            This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                                            There are no devices that have exploded or otherwise show signs...
                                            08-26-2024, 01:05 AM
                                            ESR meter came to the rescue again today with a PLC I/O card fault
                                            by sam_sam_sam
                                            I have been having a fun time at work with two pieces of equipment that had shorted components or shorted component cables to machine frame
                                            I would check what my multi meter was telling me about how many ohms I getting with the multi meter was telling versus the ESR was telling me about weather or not it really was a short to machine ground or not
                                            One note at first we thought that it might be a bad I/O card or a malfunction PLC including me as well but I thought I would try and see if removing the I/O cables would make a difference or not and this time it did make a difference...
                                            12-18-2023, 08:17 PM
                                          • FlailingEngineer
                                            Help with Bush Tv (Vestel 17mb95m Mainboard)
                                            by FlailingEngineer
                                            Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
                                            Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
                                            05-31-2023, 06:52 AM
                                          • cazi1001
                                            Strange fault on Lenovo ThinkPad E14 Gen. 2
                                            by cazi1001
                                            I have a strange fault with a Lenovo ThinkPad E14 G2 (Board No. NM-D011 Rev. 1.0).
                                            The first Problem, which I fixed already, was a dead TPS65944AD (USB Type-C) controller. After I fixed this fault, all functions working fine and the notebook run very well with the charger and battery.
                                            On the next day, I tied to start the notebook with the battery, but nothing happened. I started with the charger and on windows, I saw, that the battery was empty. And this was nearly impossible, because the battery was charged. I disconnected the battery and found out, that the board...
                                            03-24-2024, 04:16 AM
