Sony KDL 52W5100 No Picture but sound
  • kk325ic
    • Mar 2013
    • 11
    My Sony KDL-52W5100 quit working after 3 year's service. The sympton is: 1) No picture
    2) audio works 3) back light works
    I checked the fuse on T-Con board, it seems okay with 0.3 Ohm. I seriously suspect either the main board or the t-con board has problem.
    Consider $1500 for just 3 years, it seemsTV industry gain a pvery high margin profits. Not ready to dump this TV yet, if I can repair it. Any input is appreciated.
    Here are the pictures of the boards after removing the back cover of the TV
    Re: Sony KDL 52W5100 No Picture but sound
    Do you get any DC voltage on that T-CON fuse?
    • atef33
      • Feb 2013
      • 8
      • italy
      i had the same problem with sony 40v 2000 i changed t-con board and the tv now is all right
      • kk325ic
        • Mar 2013
        • 11
        Yes, I measure it. One side is 12.4v and the other side is 12.3v. Besides the T-Con fuse, what could be potential pitfalls?
        • kk325ic
          • Mar 2013
          • 11
          I would like to get a t-con board to try it out. It seems not easy to find one for my model.
          Called Sony and they don't sell it.
          • atef33
            • Feb 2013
            • 8
            • italy
            look inside this site certainly you find it :FlatTVParts.co.uk
            • kk325ic
              • Mar 2013
              • 11
              I am a newbie on this site. Please help me locate the parts. I believe the parts number is 52NU_MB3C6L v0.7
              thanks in advance.
                You need to match the P/N of the printed circuit board assembly number (not the blank circuit bord number), the PCBA number is usually printed on the bard code.
                Check out www.shopjimmy.com
                • kk325ic
                  • Mar 2013
                  • 11
                  how likely the main board could be wrong? I am thinking where should I start - replacing t-con board or the main board?
                    I lean toward bad T-CON, it is cheaper than the main board most of the time. Make sure to use the silicone heat transfer pads that are on the old IC and on the cover.
                    • kk325ic
                      • Mar 2013
                      • 11
                      Let me order an t-con board ...
                      • kk325ic
                        • Mar 2013
                        • 11
                        thanks for everybody's help. The new T-Con board fixed the problem.
