technika 42 lcd 910 power probs
  • exmortis
    • Feb 2013
    • 27
    • u.k
    Re: technika 42 lcd 910 power probs
    Originally posted by tom66
    You need to use low-esr capacitors. Farnell sell them as do RS. Capacitors from the average shop can cause lots of issues. Good capacitors to use are Panasonic FC, FM or FR.
    ok i have some others now good ones i try them instead now and keep ya posted many thanks
      Which ones do you have? Brand and series? Seriously, most capacitors are NOT suitable.
      • exmortis
        • Feb 2013
        • 27
        • u.k
        they where capcon ones same as removed , tv does the same , and i checked the 24v to the invertor and they do get a feed briefly then the tv clicks back off and the voltage drops off.
          Capxon are really poor capacitors.... I've replaced more of them than any other...
          • exmortis
            • Feb 2013
            • 27
            • u.k
            ok if i sort them what would be the next step to test ? iam stuck now on what to check.
            • exmortis
              • Feb 2013
              • 27
              • u.k
              #26
              what about Rubycon capacitors ?
                They are very good, but you can get a lot of fakes if you buy from shady shops, let us know the series (e.g. ZLH, YXF, MCZ) before replacing them as we need to know if they are low esr (not all Rubycon caps are.)
                • exmortis
                  • Feb 2013
                  • 27
                  • u.k
                  #28
                  they are MCZ are the series anygood
                  • exmortis
                    • Feb 2013
                    • 27
                    • u.k
                    #29
                    would increasing the microfarad on the replacements cause a issue i.e going from 470 to 1500 same voltage tho ?
                      Yes, almost certainly. And, MCZ are not suitable for TV PSU.
                      • exmortis
                        • Feb 2013
                        • 27
                        • u.k
                        #31
                        what next thing i can test once the caps are sorted ?
                          We can check the output rails and main board.
                          • exmortis
                            • Feb 2013
                            • 27
                            • u.k
                            #33
                            ok i been testing and checking components , i found a 4.7Mohm resister open circult which i replaced has resolved the buzzing issues from power supply, still remains in standby, i just been testing Mosfets on invertor and found n channel bottom 4 are at fault model fdd8447l 40v , iam right in saying they operate similar to diodes back to back and only allow current one way through ?
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              #34
                              http://howtoblogpost.blogspot.co.uk/...st-mosfet.html
                                That is stolen verbatim from 4QD.
                                http://www.4qd.co.uk/serv/MOSFETfail.html
                                http://www.4qdtec.com/mostest.html
                                • exmortis
                                  • Feb 2013
                                  • 27
                                  • u.k
                                  #36
                                  yeah i think the 4 mosfets on the invertor next to the 2 caps are knackered i have to get some and change them and see what happens
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    #37
                                    sure is stolen a good testing guide though tom can these be tested in circuit or have to lift the fets legs? i am never sure
                                      In circuit is usually OK, once a suspicious device is located, remove it from the circuit and test out of circuit.
                                      • exmortis
                                        • Feb 2013
                                        • 27
                                        • u.k
                                        #39
                                        anyone got 4x FDD8447l mosfets they can send us in the post, cant get any at the mo
                                          *cough*
                                          http://www.ebay.co.uk/sch/i.html?_tr...at=0&_from=R40
                                          • malogro
                                            Acer Nitro 5 AN515-55-55M1 [GH51G mb] powers on, no vcc_core
                                            by malogro
                                            Hello all,
                                            I'm stumped on this guy, so wanted to see if anyone has any further ideas:
                                            Intro:
                                            This is an Acer Nitro 5 AN515-55-55M1 with unknown prior history (bought "as-is" on eBay). It charges the battery and powers on from both AC adapter and battery, so I think this rules out main power issues.
                                            Upon attempt to boot, it will "reboot" (meaning powers down and then powers on again) only once, and then stays stuck in a status of lights on / no post / no monitor. Powering on with fn+esc maxes out the fans on first boot attempt,...
                                            04-14-2023, 04:44 PM
                                          • jose6326
                                            Samsung s32d850t powers off
                                            by jose6326
                                            Powers on as normal shows an image then powers off after 10 seconds
                                            I have to unplug it from the wall and replug to get it to turn back on but then shuts off
                                            No blown caps
                                            I searched for this model but nothing comes up...
                                            11-29-2024, 11:21 PM
                                          • Rekoo1997
                                            DELL Precision 3520 powers on automatically
                                            by Rekoo1997
                                            Laptop Model: DELL Precision 3520 Motherboard: CDP80 LA-E152P Rev 1.0 (A00)
                                            Issue: The laptop powers on automatically after being shut down.
                                            Actions Taken by Technician:
                                            BIOS reflashed
                                            Intel ME region cleared
                                            Result: Issue still persists
                                            Additional Observations:
                                            Power button reads 3.3V (normal)
                                            The problem occurs both when running on battery and when connected to AC adapter...
                                            08-07-2025, 08:48 AM
                                          • simwalsh
                                            Philips 47PFL4606 Powers on, works normal then powers off after a minute
                                            by simwalsh
                                            I am new to this forum and have searched for some answers with problems similar to mine.
                                            Philips TV powers on as normal for about a minute or less then click and no power at all not even standby light. If i disconnect from mains and reconnect it will power on again but for a shorter time. Once i leave it disconnected from main for a longer time it will power on for a longer period the next time.
                                            It sounds like a power supply issue?
                                            I have the board out and want to run some tests. Not sure what i should be doing but i put a 1k resistor across SB and +5v...
                                            12-04-2023, 04:03 AM
                                          • csmith
                                            Vizio D50u-D1 Powers up no picture
                                            by csmith
                                            I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
                                            Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
                                            supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
                                            issue. Set will power up with remote but not power off....
                                            07-11-2025, 11:52 AM
