technika 42 lcd 910 power probs
+ More Options
Posts
  • exmortis
    • Feb 2013
    • 27
    • u.k
    hi having probs with this , the unit powers up and the screen lights up for 20sec's and then powers down again , and the psu 17PW01-4 buzz's any ideas with this issue common i seen, cant see any badcaps on the board.
    Re: technika 42 lcd 910 power probs
    Your fault is different from last guy's. Check 24V across CapXon on inverters.
    • exmortis
      • Feb 2013
      • 27
      • u.k
      ok all new to me , so i wouldnt know how to check that , i been told it could be a diode gone open letting through A.C
      • exmortis
        • Feb 2013
        • 27
        • u.k
        also the screen does not display anything , just the backlight on a black background ?
        • vinceroger69
          • Mar 2012
          • 6714
          is you multi meter auto ranging or manual can you post pictures of the boards on your set they we can point out for you the test points etc.
          • exmortis
            • Feb 2013
            • 27
            • u.k
            manual meter i add some pic's
            • exmortis
              • Feb 2013
              • 27
              • u.k
              the buzzing is coming from the little transformer fella i have high marked on the pic's , also marked these diodes which i was informed might be at fault
              • vinceroger69
                • Mar 2012
                • 6714
                put you meter on diode test and the three diodes you have highlighted should have a reading in one direction only if any read odd you will have to unsolder 1 leg on each diode and then retest them.
                tom will explain what he needs tested and how ie meter setting etc if your not sure.
                if your not sure of the meter settings post a picture up and we will highlight the diode and dc settings for you
                  This pic: https://www.badcaps.net/forum/attach...8&d=1361530364
                  Two brown caps (cylinders) on inverter board: check voltage across them.
                  • exmortis
                    • Feb 2013
                    • 27
                    • u.k
                    hi all thanks for quick replys ok
                    the diodes i get the same for all 3 a reading of 127-130
                    and the voltages accross the brown caps one reads 24v and the other only 5v the t.v slips back into standby, the caps look like they have been changed before lots of flux resin and moody solder joints.
                    • exmortis
                      • Feb 2013
                      • 27
                      • u.k
                      ok got 24v from both brown caps
                      of them on the invertor boards before she shuts down .
                        Ah, so you get 24V, then it rapidly falls off? When it does this, does the power LED begin blinking?
                        • exmortis
                          • Feb 2013
                          • 27
                          • u.k
                          power led does not blink at all, i changed some of the caps on the isolated side of the psu, same as the other chap did, and now it switches on and then back off within a couple of seconds
                          • exmortis
                            • Feb 2013
                            • 27
                            • u.k
                            i double check the led on the front tho now
                            • exmortis
                              • Feb 2013
                              • 27
                              • u.k
                              blue button stays on now solid on the front .
                              • exmortis
                                • Feb 2013
                                • 27
                                • u.k
                                i replaced the caps in red on the pic, now she switches on then off .
                                • exmortis
                                  • Feb 2013
                                  • 27
                                  • u.k
                                  or completely stuck in standby mode help
                                    Do you have 24V on those caps briefly when power is first applied to the set?
                                    What brand and series of capacitors did you use?
                                    • exmortis
                                      • Feb 2013
                                      • 27
                                      • u.k
                                      yeah i get 24v the it drops off and the cap's have no brand just some i picked up at the local electronics shop to match the ones to replace , 470micro 16v
                                      but the behaviour of the fault has now changed
                                        You need to use low-esr capacitors. Farnell sell them as do RS. Capacitors from the average shop can cause lots of issues. Good capacitors to use are Panasonic FC, FM or FR.
                                        • malogro
                                          Acer Nitro 5 AN515-55-55M1 [GH51G mb] powers on, no vcc_core
                                          by malogro
                                          Hello all,
                                          I'm stumped on this guy, so wanted to see if anyone has any further ideas:
                                          Intro:
                                          This is an Acer Nitro 5 AN515-55-55M1 with unknown prior history (bought "as-is" on eBay). It charges the battery and powers on from both AC adapter and battery, so I think this rules out main power issues.
                                          Upon attempt to boot, it will "reboot" (meaning powers down and then powers on again) only once, and then stays stuck in a status of lights on / no post / no monitor. Powering on with fn+esc maxes out the fans on first boot attempt,...
                                          04-14-2023, 04:44 PM
                                        • jose6326
                                          Samsung s32d850t powers off
                                          by jose6326
                                          Powers on as normal shows an image then powers off after 10 seconds
                                          I have to unplug it from the wall and replug to get it to turn back on but then shuts off
                                          No blown caps
                                          I searched for this model but nothing comes up...
                                          11-29-2024, 11:21 PM
                                        • simwalsh
                                          Philips 47PFL4606 Powers on, works normal then powers off after a minute
                                          by simwalsh
                                          I am new to this forum and have searched for some answers with problems similar to mine.
                                          Philips TV powers on as normal for about a minute or less then click and no power at all not even standby light. If i disconnect from mains and reconnect it will power on again but for a shorter time. Once i leave it disconnected from main for a longer time it will power on for a longer period the next time.
                                          It sounds like a power supply issue?
                                          I have the board out and want to run some tests. Not sure what i should be doing but i put a 1k resistor across SB and +5v...
                                          12-04-2023, 04:03 AM
                                        • SarcasticOP
                                          General question about MacBook power rails for repair.
                                          by SarcasticOP
                                          I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                                          • PPBUS_G3H (12.6V-12.8V)
                                            • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                                          • PP3V42_G3H (3.42V)
                                            • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                                          • PPVRTC_G3H (3.3V)
                                            • This
                                          12-12-2024, 05:50 PM
                                        • CornholioGSM
                                          Dell P2720DC - Powers on only in test mode
                                          by CornholioGSM
                                          Hello
                                          I have Dell monitor P2720DC.
                                          Monitor powers on without problem, but shows only panel test - WRGB filled display - and i am unable to exit this mode...buttons does nothing.
                                          Is here any fix for this?
                                          Maybe reprogramm SPI with working img ?
                                          Monitor board is 715GA309-M02-000-0H5I...
                                          02-15-2025, 10:21 AM
