Panasonic TC-P50G10, 7 & 6 blinks
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TC-P50G10, 7 & 6 blinks
    Originally posted by johnboy1313
    Check out the first post in this thread and the troubleshooting guide attached to it.
    https://www.badcaps.net/forum/showthread.php?t=24894
    That guide's 10th gen 2007.
    "the 2008 models are designed not to turn-on if either the SU or SD board is disconnected."
    His is 12th gen, 2009. Ideally even if his SC fails, the bypass, the buffers should still be checked for shorts.
    • inferno12
      • Feb 2013
      • 10
      • US
      I got the new SD board in and get it all put together and I still got 7 blinks. I guess I need to get one of the jumper things? UGH......So frustrating when I know just enough to get this far but not enough to get farther. johnboy1313, what did you replace to get yours fixed?
      Can anyone suggest my next step or is it to get one of the jumpers and test it?
      Thank you
      • smartjohn
        • Feb 2013
        • 116
        I am fighting the same battle on the 42 Inch Viera (TC-P42G10) https://www.badcaps.net/forum/showthread.php?t=26767 I believe the problem on mine may be a bad SU buffer board. I would pull both buffer boards completely out of the set and check all pins on the power connectors to the Ground tab (where the larger screws bolt to the SC board.) I found a low reading on my SU board and do not think this is normal. I'm waiting for more input from others at this point. Good luck!
        • treid
          • Aug 2013
          • Czech Republic
          Hi there, i have a similar problem with my P50G10E set, if i turn on TV i got 7 red blinks.
          I examined a TV service guide, and I concluded that I have a defective SU and SD board.
          If i disconnect SU and SD board and put jumper to SC42, TV boots up black with no errors. If i disconnect only SU or SD board with jumper on SC42 i got always 7 red blinks.
          So I want to ask whether you think it's a good idea to replace the SU and SD boards?
          prekladac One more thing, I found on the panel one dead pixel, it is possible that it could shorted SU or SD board?
          Thank you in advance
          Treid
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
            After all of...
            07-13-2024, 08:14 PM
          • canadaboy25
            Panasonic TC-P54VT25 No image. A or D board?
            by canadaboy25
            I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
            I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
            01-17-2021, 01:06 AM
          • Biruslapio
            Panasonic P50VT20B Plasma 12 Blinks, Power Supply or A-Board?
            by Biruslapio
            Hello, I've had this TV for 3 years, 2 years ago it stopped working signaling 12 Blinks, SOUND_SOS according to the service manual.
            It has no VSUS or VDAT, and P15V has 1.0V instead, the same 15V goes to A board. F15V is ok and other main voltage rails.
            It seems the power supply is defective, since unplugging D20 ribbon cable that goes from D-board to SC-board makes the behavior change, the TV stays on, there's no image nor VSUS, but 15V reads 2.4V, high enough to not trip the SOS 12 blinks, so it stays on, fans do not spin but I left it 2 hours, green led lit up...
            02-16-2021, 09:44 PM
