Th-58ph10bk
  • simplytrini
    • Jul 2011
    • 73
    Th-58ph10bk
    Hi all, I am looking for assistance with the repair of a Panasonic Plasma Display TH-58PH10BK. The issue is when you turn the set on you hear the relay click then I get the LED flashing 2 times. According to the service manual it says that P-Board, D-board or DS-board is likely. With the intent to save time i ordered replacements for all three boards however that did not resolve the issue. I did some more troubleshooting and found that when I disconnected the flat cable at D31 which connects D-board to the C1 board and the cable at C33 which connects C3 to the SS-Board the set stays on with full control of the volume, inputs select etc, but no display. I then replaced C1, C2 & C3 which also did not fix the issue. Not sure what else to check. If anyone can help it would really be appreciated.
    Thanks In Advance
    Matt
    Re: Th-58ph10bk
    Check the Vsus voltage on the PSU.
    • simplytrini
      • Jul 2011
      • 73
      Re: Th-58ph10bk
      Because I feel that there are many times post go unresolved I thought I should post what I found. With the symtoms I have mentioned in my earlier post, I eventually found this set to have a bad plasma panel. I removed all the Address Boards at the bottom of the set and the tv fired up with a white screen with large red and black blotches. I was really hoping to save this TV but Oh well A great learning experience. Lots we can learn here - Eg. https://www.badcaps.net/forum/showthr...t=30067&page=1
      Thank you TOM66 for all you do here and everyone who is willing to help out. Keep up the Great Work!!!
      • rounin
        MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
        by rounin
        🛠 Original Issue
        ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
        04-19-2025, 01:18 AM
      • ugamazing
        by ugamazing
        12-17-2024, 07:05 PM
      • ahmarzo
        Acer laptop battery draining issue
        by ahmarzo
        Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
        Help me to diagnose this issue as there is no shortage in the inputs MOSFET
        08-02-2025, 06:39 AM
      • elmark
        HP 15-cw1002ua strange keyboard issue
        by elmark
        HP Pavilion 15-CW1002UA
        S/N 5CD0251CBC
        P/N 7KE54EA
        Hello guys!
        I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
        It powers on OK and has no other issues except the following:
        • CAPS LOCK does not work at all
        • Fn button toggles Flight Mode
        • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
        • (with SHIFT pressed: 't%' and 'y^' respectively)
        I initially thought it was a keyboard malfunction (internal short, etc.),
        but when I press and hold...
        06-27-2025, 01:10 AM
      • Simone Vergani
        Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
        by Simone Vergani
        I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
        To assist with troubleshooting, I'm attaching two power circuit schematics:
        • Power
        03-05-2025, 02:25 PM
