Plasma TV keeps shutting off/hibernation
  • somerandomguy
    • Feb 2013
    A friend of mine just called me asking about her Vizio Plasma tv that seems to be dying and I have no experience with Plasmas at all.
    Apparently it just started doing this and it varies in time every five or ten minutes. I'm not sure if it stays on longer after it has been off for a while or not. She said it goes into it's hibernation mode and she has to actually turn it off and then back on. When it shuts off it makes the sound it makes when it turns on except that sound lingers and there is somewhat of a buzzing sound.
    I don't want to influence your opinion but to me it sounds like something with the power supply is going but like I said, I have no idea how plasmas are.
    Any ideas?
    Re: Plasma TV keeps shutting off/hibernation
    If there's no picture issue or problem with the sustain boards, you'd treat this exactly like an LCD TV shutting off/hibernating.
    • somerandomguy
      • Feb 2013
      Sorry, should have clarified. I know nothing about the LCD TV's also. The only tv's I've dealt with are LCD DLPs.
      And yes, she said the picture was fine.
        Oh OK. But despite appearances, there are quite a few similarities between rear projection and flat panel. Main board is usually the same or very similar, PSU is quite similar (though usually no ballast output) etc.
        • Maniackk
          Yoga 530-14ARR NM-B781 Ryzen 3 2200 – overheating and shutting down under load
          by Maniackk
          I’ve got a stubborn patient here. The laptop powers on and works, all components like the screen, keyboard, touchpad, etc. are functional. The issue is that it heats up very quickly under load (within a few minutes up to 95°C) and then shuts down shortly after. Subsequent attempts to turn it back on right after a “hot shutdown” result in it shutting off within a few seconds. Interestingly, if I enter the BIOS, it can stay there for 2 days without shutting down (most likely due to low CPU load and low temperatures).
          The cooling system has been cleaned, thermal...
          09-03-2025, 09:32 AM
        • rumpumpel1
          Lenovo X13-Yoga Gen 1: hibernation problems
          by rumpumpel1
          I have a Lenovo X13-Yoga Gen 1 that has problems with hibernation mode. When the laptop goes to hibernation mode - either via the start menu or after a time-out - after a short period of activity where the power-on LED flashes, the power consumption should go down to almost 0 and the LED should go out. Most of the time, however, the power consumption indicates further CPU activity and the power LED remains on, but there is no image. Sometimes the CPU activity stops after a few minutes, sometimes not at all. If the laptop enters this state, it can only be brought back to life by a long press on...
          11-03-2024, 12:31 AM
        • ArMaaN376
          Samsung PS51E550 Plasma TV
          by ArMaaN376
          I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
          Opened TV cover & observed foll
          a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
          b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
          c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
          How to confirm Y -Buffer board...
          06-19-2024, 04:05 AM
        • jm1234
          Panasonic plasma TX-P42ST50 - 6 blinks
          by jm1234
          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
          I checked that board for any obvious faults...
          05-22-2024, 06:59 AM
        • KYBOSH
          Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
          by KYBOSH
          Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
          No picture but you hear the TV static (white noise) playing loud and clear.
          The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
          But it seems they didn't get too far and just left it.
          When I first took a look I was amazed at how pristine the inside looked.
          Its as if the TV had been in a time capsule.
          Caps looked like they were just pulled off the self.
          Copper coils had no sign of corrosion on...
          02-01-2023, 11:10 PM
