Panasonic TCP50GT20
    Re: Panasonic TCP50GT20
    Nice professional job. Does the case have positions for fans? Seems Panasonic have added fans in recent versions (GT30 onwards) after removing them... probably due to reliability issues.
    • rcpilot82
      • Feb 2013
      • 33
      There are several stand-offs on the display for what may be a fan array as the location is correct, However, none of the standoffs are tapped. I did not want to go making metal chips in a fully assembled set.
      I checked the clearances between the mounting supports and the back cover and there was more than enough room to do the fan shroud as I did it with no interference. FWIW, the back cover only contacts the mounting supports on the vertical portion. the angled sections have about 1/4" (6mm) clearance.
      • rcpilot82
        • Feb 2013
        • 33
        Figured I'd give a conclusion to this thread. I hooked the TV back up as it was yesterday and it was on for about 5.5 Hrs straight. The only spot that has any heat to is is by the A board. I think if someone wanted to add a dedicated fan to that board it would be benificial. The screen was much cooler to the touch and I could feel no heat increase around the PS,SS,SD boards. The fan mod made a Huge difference overall and was well worth the effort. The only change I would make to the mod would be to move the shroud down about 1/2" to 3/4" for a little more clearance for the fan frame. It works well as is though.
        There was some concern about the DC-DC introducing noise back into the display. I used several diffrent inputs and settings and noticed nothing to indicate this was occuring.
        Thanks for all the help, hopefully the many points we covered here will help someone else along the way.
        • Soulzink
          Samsug washing machine. Power supply DC41-00189a board issue
          by Soulzink
          I am trying to fix a samsung washinmachine power supply main board.
          I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
          Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
          The power supply board reference is the following: DC41-00189a
          I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
          04-19-2025, 06:26 AM
          After all of...
          07-13-2024, 08:14 PM
        • canadaboy25
          Panasonic TC-P54VT25 No image. A or D board?
          by canadaboy25
          I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
          I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
          01-17-2021, 01:06 AM
        • Asraf Atb
          Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
          by Asraf Atb
          Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
          Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
          I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
          01-27-2025, 05:02 PM
        • Stephen
          A2991 Logic Board issue, 20volts 0 amps help!
          by Stephen
          Customer plugged in samsung monitor into the board and used it as a power supply, killed UG800 and UG400. I replaced those two with an exact donor board we had In stock and working, board pulls 5volts and then gets like 2.89 amps on the left side. The singular port is the port that failed. Used a perfectly working chips from donor (board was locked) Now I only get 5volts 0 amps on that power and then 20volts 0 amps on the two left side ports, I checked for DFU and nope nothing, computer not turning on. No shorts present anymore. I am confused as I used the exact components from an identical...
          09-10-2025, 03:16 PM
