Panasonic sc tnpa5081 rebuild
  • Tech 57
    • Aug 2014
    • 37
    Re: Panasonic sc tnpa5081 rebuild
    they shipped it today when i get back i will post pictures
    thanks phil
    • Stryff
      • Oct 2013
      • 16
      I ended up sending my board to PTS, they did an excellent job & I had even removed components before sending it to them... looked factory. Although my board didn't have a burned trace!
      • tw2005
        • Oct 2011
        • 6458
        Been busy this week tidying up loose ends on a few boards I had busted but been too lazy to get into it.
        Did another 5081 which I'd started which is not ideal if you don't take notes of what's been done.
        So result of that was it failed, blowing 90% of the bits I'd just done.
        anyway I had forgotten about a couple of resistors that were a bit brown, R421,R422. They were open, so redid the board, replaced those 7.5 ohm gate resistors and this time all good.
        First one of these I've done with those bad.
        Also I subbed RJP56F4A for the DG502 and no dramas there.
        • 11alon11@gmail.com
          • Sep 2014
          • 15
          • canada
          #384
          I have tried to rebuild 2 boards TNPA5105 and TNPA5081for the TNPA5105 I used the shopjimmy kit and for the TNPA5081 i used the Zentronix kit. Both of the board's will power up and not blow anymore parts but I get the 6 blinks on both with the short on the 50 connector. I have checked and rechecked with no success no parts blow any more but I get the 6 blinks I am at a loss can someone try and help me
            • Sep 2014
            • 15
            • canada
            #385
            I have tried to rebuild 2 boards TNPA5105 and TNPA5081 for the TNPA5105 I used the shopjimmy kit and for the TNPA5081 i used the Zentronix kit. Both of the board's will power up and not blow anymore parts but I get the 6 blinks on both with the short on the 50 connector. I have checked and rechecked with no success no parts blow any more but I get the 6 blinks I am at a loss can someone try and help me
            • tw2005
              • Oct 2011
              • 6458
              Did the kits come with instructions or a parts list and locations? Can you post up images of those lists or compile a list of every part removed and replaced?
              Did you use every part supplied?
                • Sep 2014
                • 15
                • canada
                #387
                this is the list of parts replaced on the tnpa5081 rebuild
                  • Sep 2014
                  • 15
                  • canada
                  #388
                  this is what was replaced on the TNPA5105 on both after replacing the parts I get 6 blinks and no more blown parts with jumper 50 on
                  R 401 & 402
                  D451 & 490 & 491 & 618 & 652
                  D721
                  Q501 & 521 & 551
                  Q401 & 402
                  IC724
                  Q661
                  Q601 & 660
                  Ic501 & 521
                  Q451
                  Q421 & 422
                    • Sep 2014
                    • 15
                    • canada
                    #389
                    I also replaced IC771 on the TNPA5105 with no results and checking resistant on the 15v, 5v and sc2 no short, checking voltage on sc20 I do get 5v and 15v and on sc2 about 200v until the 6 blinks when voltage go down
                    • tw2005
                      • Oct 2011
                      • 6458
                      That's certainly a big list for the 5081, I would say absolute worst case scenario. The only snags I remember is missing D451 shorted causing 6 blink, or a defective SOS6 detection cct which is unusual but possible and if the onboard LED ios open cct that too will create a 6 blink.
                      I wonder if you put a part in wrong since you've managed to get the same result on 2 boards?
                      Interesting to look at that list considering it says it fixes 42C2, 55ST30!, and 54" models which have more transistors
                      • tw2005
                        • Oct 2011
                        • 6458
                        R 401 & 402
                        D721
                        Q501 & 521 & 551
                        Q401 & 402
                        IC724
                        Q661
                        Q601 & 660
                        Ic501 & 521
                        Q451
                        Q421 & 422
                        I've done a total of 1 of these. I really should keep a logbook, so hard to figure what I replaced.
                        looks like D451, R451, Q451, D482(R553?), Q551,R551, IC521
                        Q421, Q422, Q621, D642, Q401,Q402, Q660, Q661, Q701, (Q702?) IC773,
                        • Hombre
                          • Jul 2013
                          • 231
                          • Croatia
                          #392
                          Can you check MID voltage, across those blue capacitors, it should be half of VSUS, so somewhere around 100V, if it is lower than that it will trigger 6 blinks, if everything else looks ok.
                            • Sep 2014
                            • 15
                            • canada
                            #393
                            blue capacitors?
                              • Sep 2014
                              • 15
                              • canada
                              #394
                              Hi I did more work on the TNPA5081 with the 6 blink error and found that the resistant in IC771 center pin to the left is is about 900ohm and in a good board i tested its about 1400ohm any suggestions?
                              by the way MID voltage is going up to 100v and then down once it detects the 6 blinks
                              • peteburns
                                • Nov 2016
                                • Norway
                                #395
                                Hi all, please does anyone have a list of correct voltage values on this board and/or oscillograms at some important points? I fixed some Samsung plasmas but this Panasonic is too chaotical...My power board looks OK, with VSUS being +208V and Va being +60V roughly, +15V and +5V are OK too, but those output voltages from SC board are mystery - VAD, VFG, VSCN, VOL, MID...It would be nice to test all the IGBT and MOSFET control voltages and make sure they are OK before finally powering the board to VSUS :-) Thank you very much for any info ;-)
                                • peteburns
                                  • Nov 2016
                                  • Norway
                                  #396
                                  So MID voltage should be 1/2 of the VSUS, roughly +105V, and VAD is roughly -170V, while VFG is virtual floating GND, pulsating between VAD and VSUS? What about the rest?
                                  • Alastair E
                                    Chief Womble
                                    • Mar 2013
                                    • 1963
                                    • U.K.
                                    #397
                                    check out app-note in my sig. It explains how Plasma sets work.
                                    All the SC is basically is a 6 legged H-Bridge and some floating-supplies and floating driver LV supplies...
                                    TELEFIX
                                    • peteburns
                                      • Nov 2016
                                      • Norway
                                      #398
                                      Thanks for that link, but it explains sustain board working principle in details. In this topic it is more important to describe scan board instead, and, even more importantly - from practical point of view, not theoretical...People don't actually need to know, how exactly the board works, but they need to know, how to examine components, find faulty ones and measure all the important spots in order to make sure all the power devices receive correct signals, so they don't experience big bang while switching on :-) Even the advice of using some resistor or light bulb at VSUS to protect the components is not correct, it will not protect enough and that's not the way any board should be tested...As mentioned many times before, any small overlooked component can cause some signal missing or distorted with the obvious result of immediate bang, or as in tw2005's case after 90min or so - both are not good enough and can be avoided :-)
                                      • peteburns
                                        • Nov 2016
                                        • Norway
                                        #399
                                        So, the 50" plasma TV works fine again, this time I was lucky, only the SC board was faulty. Just to mention those "100% repair kits" - don't rely on them at all, at least in my case they wouldn't contain all the failed components, meaning the whole board would fail again...
                                          • Sep 2014
                                          • 15
                                          • canada
                                          #400
                                          I decided to take a look at the tnpa5105 board again with the 6 blinks and found that Zener Diodes 871 and 872 blown. replaced them and now I don't have any blink code and I do have a picture the problem is that the picture is noisy and low in brightness both when I display the menu and picture from HDMI, do you have any idea as to what should be the problem now?
                                          • tranquility
                                            Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
                                            by tranquility
                                            i want to repair an Onkyo TX-NR809 receiver.
                                            symptoms:
                                            on power on, display appears and i hear one click. enue functions is given.
                                            - no hdmi output
                                            - audio output not tested, but i think it is not there
                                            - usb sticks are not recognized
                                            if i read out the chips with display+standby button + tone+
                                            both dts show only ????
                                            chip is D830K013BZKB4
                                            things i have done:
                                            - reflow of the dts chip without taking off and reballing
                                            - changed the aluminium caps without the big one with 25v because i dont...
                                            08-25-2025, 01:04 AM
                                          • Wizen
                                            Panasonic CF-D1NW200TZ BIOS Issue
                                            by Wizen
                                            Greetings All
                                            I have Panasonic CF-D1NW200TZ,
                                            SN: 8GTSA90529
                                            The BIOS (MX25L12873F) is password-protected. I want to remove the password. I created a backup using NeoProgrammer and removed the password. Then, I restored the unlocked BIOS file using CH341A, removed the protection, performed a full wipe, completed the process with a blank check, and then wrote and verified it. Everything seemed fine, but now the tablet won't start. Only the power and Wi-Fi LEDs are lit, nothing else. The fan isn't spinning, and nothing else happens.
                                            tried to write back...
                                            Today, 02:33 AM
                                          • BigPete
                                            Panasonic Heatpump Dryer Repair
                                            by BigPete
                                            I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                                            The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                                            In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                                            Unfortunately the whole machine has to come apart to fix it.
                                            I have...
                                            11-01-2025, 06:40 PM
                                          • mattpd
                                            PS5 EDM-031 - Pulsing BLOD - SSD NAND chips never heat up
                                            by mattpd
                                            PS5 died in the middle of a game and never would boot again. Pulsing BLOD stays on forever but never boots.
                                            No LM damage. UART gives a generic "APU not responding" error.
                                            Under thermal camera, the SSD NAND chips stay stone cold. The controller warms, but not the NAND. I have a good 2.5v and 1.8v around the NANDs...
                                            I don't have a ton of PS5 experience, but I assume that the NAND would need to warm at least a little bit in order to boot...
                                            So to those with experience, would you expect at least a little heat from the NAND during...
                                            09-02-2025, 09:42 AM
                                          • Andre Gilbert
                                            by Andre Gilbert
                                            Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
                                            Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
                                            11-20-2024, 08:52 PM
