42LG30 Vetical bars
  • Mr Bill
    • Nov 2011
    • 648
    42LG30 Vetical bars
    A friend found this in the trash. Powering it on the screen starts up solid black then the bars "wash" in as seen in the picture. There are 2 ribbons that go to the panel from the tcon board. If we disconnect the one side the bars appear as soon as the backlight comes on and it's across the entire screen. If the other side is disconnected the bars are there but the other half is white.
    I would think by having one ribbon connected and the other disconnected one half would be white but it's not the case with the one side. We did check the voltages coming from the power supply and they all check out as per the legend on the board. If we hit the menu button nothing shows up on the screen.
    We did try and hook a source up on the screen and started hitting the source button and did get audio. The bars do start to strobe. The tcon board is very cheap ($13) with free shipping.
    So the million dollar question is: Does this appear to be a faulty tcon, main or panel. I don't think it's the main board since the tv turns on/off and the source can be changed but from my experience in this area i'm usually wrong . Just want to get some feedback before investing a dime on this tv.
    Re: 42LG30 Vetical bars
    Looks like t-con or panel to me, my bet would be on t-con, worth a $13 gamble for a free TV. Fading lines are characteristic of LCD driver problems -- the main board can't usually cause that.
    • Mr Bill
      • Nov 2011
      • 648
      I placed the order. I'll update this thread when i get the board. Hopefully it's not the panel but for the price it's worth the gamble.
      • retiredcaps
        • Apr 2010
        • 9271
        With the recent USPS $7 hike across all International shipping options, I can't even get an empty box filled with air shipped to Canada for $13.
        --- begin sig file ---
        --- end sig file ---
        • tibimakai
          • Jan 2012
          • 3680
          Tom, since I'm dealing with a fading to black Toshiba TV and you are saying that can also be a panel driver IC problem, that is possible that all of them are failing at once?
            How likely is it that all ICs would fail simultaneously?
            • tibimakai
              • Jan 2012
              • 3680
              Yes.
                I don't understand what you mean.
                • tibimakai
                  • Jan 2012
                  • 3680
                  It's possible that all tab drivers to go bad at the same time?
                  Only like that can the whole screen go black, no?
                    Unless the t-con kills them, which is very rare. The 15V would have to go out of control. HOWEVER, one failed IC can cause the others to malfunction.
                    • Mr Bill
                      • Nov 2011
                      • 648
                      I got the replacement tcon today and the display is exactly like before. We will just pull the power supply and inverter and ebay them. Then recycle the rest.
                      • Mr Bill
                        • Nov 2011
                        • 648
                        Before i strip the tv down and recylce it i thought i would show a video of what it's doing. My friend is stubborn and wants to exhaust all options before the tv is completley killed.
                        I said in post #1 that there was audio. I was WRONG. i've tried several times today with different devices and i cannot get any audio. He wants to know if the main board could be a "likely" cause for this fault. I think pesonally it's the panel but without audio i could be wrong. SO i told him i would update this thread one last time and get hopefully a few opinions.
                        http://www.youtube.com/watch?v=N_0Hi...ature=youtu.be
                        • MisterD
                          • Oct 2012
                          • 668
                          although you can't see any video to tell where you are on the screen using the remote control or side buttons cycle through the inputs slowly, try turning up the audio. what do you have as your source? dvd player? Cable TV Box?
                          Do you see any signs of anything other than the vertical bars when pushing the Menu button? one other suggestion is to heat the top of the panel area with a hair dryer and also try slightly twisting the panel with the back off, sometimes one or both of these methods can temporarily return to a normal screen if the panel is bad or has bad tab bonds.
                            Fading lines are panel or t-con only; the main board deals with discrete values and it's pretty uncommon for it to produce an output that fades in such a way. One thing I did notice is that TV sure takes a long time to boot. I don't know for sure if it's normal but it seems odd. Does this TV have an RS232 port on the rear?
                            • Mr Bill
                              • Nov 2011
                              • 648
                              I thought the same thing about the tv turning on slowly. It does have a RS232 port on the back of the set.
                                Using the RS232 port you can hook it up to a computer, and send it commands. There's usually a full list in the LG operations manual. Commands may be used to adjust the volume, switch sources etc to check main board operation.
                                • Mr Bill
                                  • Nov 2011
                                  • 648
                                  i'll have to look and see if one of my older computers in the basement has a COM port on it. My current computer doesn't have a COM port on it. Does this take some special software to run?
                                    Just ordinary RS232, the baud rate, parity and other settings are printed in the manual, you use HyperTerminal to send the commands.
                                    You can use a device such as this: http://www.ebay.com/itm/USB-2-0-to-R...item2c58ade216
                                    • MisterD
                                      • Oct 2012
                                      • 668
                                      ? Have you tried this?
                                      • Mr Bill
                                        • Nov 2011
                                        • 648
                                        Twisting = nothing
                                        Heating tabs = nothing
                                        Hitting the menu, volume, channel keys = nothing
                                        I've tried a dvd player with component, av, & HDMI and i cannot get sound even though i've set the player up on a working set then swapped the cables over to this tv. I even ran straight cable to the tv. I don't have a remote though i thought about (not done yet) setting up a universal remote to see if i can change the source.
                                        I ordered the RS232 cable Tom recommended to try the Hyper Terminal commands to see if the set will change sources. If the main board wasn't so expensive i'd almost try it but i don't want to risk the $$$.
                                        • Hakuu
                                          by Hakuu
                                          Hi There,
                                          More Details
                                          TV Model - LG OLED77G1PUA
                                          07-12-2023, 02:37 PM
                                        • advant
                                          by advant
                                          02-03-2020, 12:25 AM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
