LG42PC1D power board swap
    Re: LG42PC1D power board swap
    PFC circuit puts 400V across those large 450V caps on PSU primary.
    • flocko
      • Nov 2012
      • 1121
      #42
      did have the same thing with the other power board had to drop the Vs to 170v to get a cleaner video that is why i thought it was not giving out enough wattage, and why i rebuilt the old board, would a bad control board do this if you lift the Vs it looks like an LCD with a bad T-con
      • flocko
        • Nov 2012
        • 1121
        #43
        Have started from scratch with the set up again, have set
        Vs 186v
        Va 60v
        -Vy -200v this was where i went wrong yesterday if you reverse the meter leads it reads 193v or -200v when across the resistor
        Vsc 120v read 120v across the cap either way
        Vz bias 100v all voltage taken with white screen and no av input
        with the screen showing menu or the poor signal jumping around looks good, as soon as i put some video input in to it thats when it goes bad,you can still see the menu in the background, could this be a main board problem.
          You have severe image retention (IR); this is usually -Vy, Vsc or the SETUP/SETDN/RAMPUP pots.
          • flocko
            • Nov 2012
            • 1121
            #45
            Thanks tom I think your right every time i check -Vy its changed and the little stand off board when you flex it the voltage comes and goes, i will look into this and let you know what i find
            • flocko
              • Nov 2012
              • 1121
              #46
              just checked -Vy and set it again to -200v on white screen when you turn this off the -Vy jump to 239v does that sound right,in ism method i have been trying to trim in setup/ set down pots by jumping from normal/ white/ orbiter and inversion,i seem to get one looking ok then the next looks bad, do not seem to be able to get a good setting to cover them all
              In ISM the readings for =Vy
              Normal 239V
              White 200v
              Orbiter 239v
              Inversion 200v
                I would try to replace the 10u400V and 22u400V Samwha caps (RD/RG usually) on the -Vy and Vsc module, as bad capacitors can cause this issue and I have often encountered bad Samwha.
                • flocko
                  • Nov 2012
                  • 1121
                  #48
                  The ramp up in voltage from white to normal does this show a problem,and the polarity with the meter leads across the resistor why do the voltage readings change when inverted, any way am going to pull the board out and see what caps i have and change at lest the ones on the modules thanks again for your help Tom Flocko
                    Panel draws more power on white, so seeing a drop or increase in Vy with brightness changes indicates an issue with those capacitors or some other part of the Vy module.
                    • flocko
                      • Nov 2012
                      • 1121
                      #50
                      had hoped that these modules were plugins would have made life easier to change the caps, do you normally take them off the main board or do them were they stand.If i take out the two caps in between i may be able to just get in there,have to order caps think i will replace all of them.
                        Never done them myself. I'd imagine desoldering the caps from the board, with it still on the Ysus, may be possible but it will be difficult.
                        • flocko
                          • Nov 2012
                          • 1121
                          #52
                          Hi all back to this one today, have changed the caps on the stand off boards and that made it a little better, but i was still seeing the voltage jump up and down on the -Vysame as before, and the only cap i had not changed was the 150Uf 100v samwha WB, i have had a problem trying to find a replacement, i found a 100ZLH150MEFC and put that in but now i cannot get the -Vy above - 165v when i am looking for -200v can anyone put me right with this
                            ZLH may be too low ESR for that circuit. i.e. It's TOO good.
                            • flocko
                              • Nov 2012
                              • 1121
                              #54
                              Hi Tom It was about all i could find. but with it in i dont seem to be able to adjust -Vy just sits at 165/7v in full white screen but when i come out of menu back to normal -Vy jumps to 235v.
                              • m1ch43lzm
                                by m1ch43lzm
                                05-12-2025, 08:37 PM
                              • howardc64
                                by howardc64
                                Yesterday, 05:17 PM
                              • Hakuu
                                by Hakuu
                                Hi There,
                                More Details
                                TV Model - LG OLED77G1PUA
                                07-12-2023, 02:37 PM
                              • jb_Bak
                                by jb_Bak
                                CN6401
                                Pin 01 NC
                                Pin 02 NC
                                Pin 03 "BL_ON": 0V
                                Pin 04 "N/C"
                                Pin 05 "STBY 3.3V": 3.5V
                                Pin 06 "GND": N/C
                                Pin 07 "AC_OFF"...
                                09-27-2021, 04:52 PM
