Vizio E220VA no standby, no power
  • cguzek
    • Jan 2010
    • 57
    Re: Vizio E220VA no standby, no power
    U701
    1-5.09
    2-3.30
    3-0.00
    U702
    1-5.06
    2-3.32
    3-0.00
    U703
    1-3.32
    2-1.25
    3-0.00
    U704
    1-5.08
    2-3.30
    3-2.05
    sorry, they looked too close on last post, just a repost voltages across regulators pins 1-3
      They look OK, I figure you are assign pin 1 as input pin.
      • cguzek
        • Jan 2010
        • 57
        yes, sorry, pin 1 was input pin on all
        • cguzek
          • Jan 2010
          • 57
          Found it hard to trace back the K fuse to anywhere on board, such thin traces.
          Included a picture with the wires going to the standby led tiny board.
          Black wire 2.7v
          brown wire 5.0v
          red wire 3.2v
          orange wire 0.0v
          yellow wire 3.2v
          gray wire 0.6v
          • GoodOlPC
            • Mar 2013
            Subscribing, since I have the same issue.
            • thetvman1
              • Aug 2011
              #26
              Sounds like you have a bad eeprom on the main board.. I found them on ebay for $20 preprogrammed Hope this helps
              • shwsrvcs
                • Jan 2012
                • 69
                #27
                thanks! I'd posted a while back about one I had (have) that I recieved after it's owner had removed all of the caps and I didn't have any clue about what they needed to be. Now I can finally move ahead with that little project I have had sitting behind my file box! I can just match them up on the images vs the repair kit list.
                DG
                • GLISIT
                  by GLISIT
                  01-16-2025, 02:29 PM
                • x_orange90_x
                  Vizio E550i-A0 no power, no standby light
                  by x_orange90_x
                  I have a Vizio E550i-A0 that will not power on. It also does not display the standby light in the corner. I disconnected the main board cable to see if the backlights would light but they did not (maybe this is normal for this set?). I checked the voltages on the plug and they all read in mV or 0, so there's no voltage there. The fuses are ok, and the voltages of the 450v caps read about 160v. I see no visual damage on either the power supply or main board. I have read online that the main board is usually the culprit in this model, but not getting backlights with the main disconnected makes me...
                  11-20-2023, 09:49 AM
                • kitor
                  Dell Latitude 7390 - all power rails up except VCC_GT, no image.
                  by kitor
                  I have Dell 7390, LA-F311P.
                  AFAIK there's no schematics available, but there's one for LA-F312P in this thread. It differs in no Thunderbolt controller (iirc that's for 5290/5390), however rest of the schematics/BV seems to match 1:1.
                  Behavior:
                  Connected barrel plug, no RAM:
                  - power LED turns on + orange light on front
                  - turns off after a second or two
                  Connected barrel plug, with RAM:
                  - power led turns on + while light on front
                  - after a few seconds power led turns off, white light...
                  07-26-2022, 09:53 AM
                  by sam_sam_sam
                  03-31-2024, 02:12 PM
