Sylvania 6632lg vertical line
  • ryan74
    • Oct 2012
    • 471
    • usa
    A friend wants me to look at his tv. I think it was water damage. He said it happened after washing it. I will be getting it this weekend. Is this a bad panel or t-con?
    He says there is a 1.5in. vertical white line on the right side that is cloudy, changes to blue, and fades. You can see the picture behind the line.
    Thats all the info I have untill I look it over.
    Thanks for the help!
    Re: Sylvania 6632lg vertical line
    Bad panel. Newer TVs put the tabs at the bottom. Getting the TV wet will kill the panel now.
    • TrueSword88
      Kogan - KALED65XU9220STB - Blue Vertical Line
      by TrueSword88
      Hi all.
      I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
      The line just happens to coincide with the end of COF and start of the next COF (attached).
      The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
      Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
      Hoping to fix...
      05-05-2023, 04:28 PM
    • almarhum
      To fix laptop screen vertical line by working on its EDP cable
      by almarhum
      Has one here really gone through fixing laptop screen vertical line(s) by repairing/replacing its Embedded DisplayPort (EDP) cable, so would recount and share the complete steps of the process here now?
      As most, if not all, believe the laptop screen vertical line(s) caused by defective Embedded DisplayPort (EDP) cable which slipped and passed through either laptop screen hinge but post here is asking help to elaborate definitively the useful, real knowledge of repairing in the most complete, correct way, esp. can decide/determine whether the cable can still be fixed or must be re...
      05-07-2024, 02:12 PM
    • mrsith
      Samsung UE58TU7100K - no picture, vertical line
      by mrsith
      Hi.
      Got UE58TU7100K with no picture - backlight comes on though. Figured out that's a perfect candidate for cut tape method.
      This model has just one LVDS tape coming off main board - and two panel boards underneath the LCD screen are connected to each other via small tape. Like curved screens. I've tried to disconnect half of the screen (5he side without LVDS connector on it, obviously), no joy.
      Disconnected the tape (main board side). Applied a small piece of tape, covering first ~4-5 pins. Powered the TV on - got picture. In negative, but that's...
      02-07-2023, 11:18 AM
    • bdalkiran
      55EC930V white vertical line appeared (need help)
      by bdalkiran
      Dear All,
      I have 7yrs old LG OLED 55EC930v. One day a white line appeared on mid of the screen. 10mins later it was disappeared. When turned on tv again it was appeared again. Currently when power on tv is clicking sound relay, LG logo illuminates, 3 seconds later clicking sound relay and tv goes off. Screen is black during this on off period. When trying with service remote(pwr on) , clicking sound, white vertical line appears on screen(drawing line from up to down) and clicking sound then tv goes off. Please see video below.
      Please advice how to proceed and what is the...
      01-13-2023, 04:16 PM
    • tmhobadcap
      VIZIO M60-C3 Can the vertical line be fixed?
      by tmhobadcap
      I am trying to help my friend to fix his Vizio tv with a vertical line on the screen. The line is on the right side. It is blue/purple on the right side starting from the top. But it only goes to about 3/4 of the screen height (not to the bottom of the screen). It is very obvious when the screen is dark and it is hard to be seen when the screen is bright. Please help....
      02-05-2023, 03:37 AM
