47 philips pfl7432d, screen is dimming.
  • gustav
    • Nov 2011
    • 80
    I bought this for 35.00 and decided to attemp to fix it. Worse case, is i'm out 35.00. Not a bad risk. the screen lights up but it seems dim all over and one side is starting to become darker. Which leads to a couple of ways to address this. But, my wife now has my dmm and all of my tools. Yep, they are gone into the divorce abyss forever. So. I'm essentially starting from scratch here. I would like to get a inexpensive dmm. just to get by, until my resources are available to buy a decent one. ANy ideas on a cheap dmm?
    I'll been posting the pics tomorrow. and try to check out some voltages first. I will try to get the in voltages on the inverters first to see if the smps is pumping out the right juice, check caps on the inverters, and try to see what coming out of the inverter, if possible
    Thanks again,
  • retiredcaps
    • Apr 2010
    • 9271
    Re: 47 philips pfl7432d, screen is dimming.
    What is your budget?
    Update your profile so we know at least what country you reside in.
    --- begin sig file ---
    --- end sig file ---
    • gustav
      • Nov 2011
      • 80
      UPDATE: Found the caps on both the master and slave blown and leaking. Ordered the Panasonic FR caps and got them today. While trying to get the tv up so I can start to work on it, the screen cracked. . So to work on it is is somewhat futile. I guess the inverter boards can be fixed and the boards parted out. But I'm so disgusted right now, perhaps that will be another day.
        How did you crack the screen lifting it up? I've broken a screen before, but it took a lot more force than that.
        • gustav
          • Nov 2011
          • 80
          Actually Tom, I tried to "roll" or push the TV on the bed . It was positioned against the bed so I was able to pick up the bottom and dragged the tv onto the bed. And then I flipped it over onto the pillows so I could take pics before I started to work on it. I guess something could have caught while lifting it or it torqued enough to put a small crack in the bottom center. There was nothing on the bed, like a screw or anything like that. The other night it sipped from the wall onto the floor, but i started it up afterwards and it was fine. I need to mention the TV was made in 2007 and weighed around 75 pounds.
          • HTR-Informatique
            Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
            by HTR-Informatique
            YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
            I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
            On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
            I also changed the screen because the PC fell and the screen was broken.
            I changed the battery with a new and original battery.
            I also had corrosion/oxidation on the...
            02-09-2025, 06:51 AM
          • Swedishpower
            Dell G3 15 3500 black screen
            by Swedishpower
            Hello
            I have search everywhere for a solution for my problem, but cant find it anywhere.
            When I was away to trow some garbage i always look in the electronic bin.
            and this time i find a laptop.
            Dell G3 15 3500, when I get home i look at the battery, add one harddrive, plug in the powercord.
            the lamp for charmig is white.
            Tryed to start it, the screen blink for a second, the keyboard lightsup, the fans and HD starts.
            but no Dell logo.
            I tryed with a hdmi cable to another screen, still black.
            I started to search solution and tryed...
            07-06-2025, 06:18 AM
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
          • smic717394
            by smic717394
            07-25-2024, 10:16 AM
          • howardc64
            Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
            by howardc64
            Problem
            Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
            Model & Board Pics
            Conflicting Spec
            Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
            https://www.shopjimmy.com/vizio-gj-2k1...
            10-10-2024, 01:16 PM
