Cap Identification help. Vizio E470VL main board cap
  • RKnep
    • Feb 2013
    • 4
    Having trouble identifying this buldging cap.
    07
    470
    EZD
    I can't find the schematic for the board.
    I saw a pic on here of the same board with this cap that was marked
    0P
    470
    EZD
    Any help would be much appreciated.
  • RKnep
    • Feb 2013
    • 4
    Re: Cap Identification help. Vizio E470VL main board cap
    Also, just saw a cap on the same board marked
    Q3
    470E
    CD
    • mariushm
      • May 2011
      • 3799
      I can't tell who made the capacitor from the color combination.
      BUT, Panasonic and other manufacturers use the following codes for voltage rating:
      Letter Voltage
      e 2.5
      g/G 4
      j/J 6.3
      A 10
      C 16
      D 20
      E 25
      V 35
      H 50
      So your capacitors is most likely a 470uF 25v capacitor. And the ZD might be the series but I don't think it's Nichicon ZD.
      ps. And the ones with C at the beginning of the three letter code might be rated for only 16v.
        Looks normal to me -- the vent will appear to split if cap is actually failed.
        • RKnep
          • Feb 2013
          • 4
          It's bulging up pretty bad. The vent marks are actually pushed out.
          Thanks. I think I'll go with a 470uF and I might just go with a 50V.
            I've seen new from the packet caps look just like that. You should use two soldering irons, or a hot air station. One iron only will rip off the pad.
            • Dani_2024
              by Dani_2024
              10-28-2024, 05:06 PM
            • ygorsan
              by ygorsan
              🧩 Problem Summary:
              • I
              07-28-2025, 08:34 AM
            • jb_Bak
              by jb_Bak
              CN6401
              Pin 01 NC
              Pin 02 NC
              Pin 03 "BL_ON": 0V
              Pin 04 "N/C"
              Pin 05 "STBY 3.3V": 3.5V
              Pin 06 "GND": N/C
              Pin 07 "AC_OFF"...
              09-27-2021, 04:52 PM
            • JDC
              (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
              by JDC
              ONN 100012588
              Issue: No Power, Then Rebooting After Main Board Change
              Short answer: replace main board and power board
              Technical answer: replace main board and Q306 & Q307 on power board.
              Long answer:
              TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
              07-15-2022, 07:39 AM
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
