LG 32LC2D TV backlight out, then menu out (fixed - C208)
  • blargg
    • 51
    I picked up an LG 32LC2D-UD TV (April 2006) on the side of the road recently. Was very dusty, and back had been unscrewed completely in apparent attempt to diagnose. Visual inspection showed no bulged caps except one smaller one very slightly bulged.
    Powered on and green light flashed for a while, then steady. Black screen, no backlight. Flashlight showed menus appearing. Powered on and off many times while looking for best universal remote code. Then one time it turned on, backlight was working fine, but screen was now black and showing no menus.
    Today I replaced the slightly bulged cap, C208 on the main switching power board, center-right, next to right upper heat sink. It was a 680uF 16V (SAMXON black shell, 105 C GF(M)), which I replaced with a 1000uF 16V I had removed from a junk PCB in my bin. TV's worked perfectly afterwards, and I notice that flashing green light when first powering up lasts about half as long as before. Too bad I hate digital TV picture quality, deinterlace artifacts, etc. Will probably give to family member.
    It still surprises me that a little cap like that could be causing such trouble.But that was the same fix on that Dell LCD monitor before this. I'm also surprised at how subtle the bulge was visually. Before I replaced it I kept shining a flashlight at it asking whether it was really bulged.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: LG 32LC2D TV backlight out, then menu out (fixed - C208)
    Samxon GF series are a "known" bad series of caps. They don't last very long.
    --- begin sig file ---
    --- end sig file ---
      LCD LED TV Service Menu Codes
      TCL LED TV Service Menu Code
      LG LED TV Service Menu Code
      10-31-2024, 03:58 AM
    • Retro140
      Unnlock Menu for 2007 DU-27FB32C comerrcial CRT TV
      by Retro140
      So I was referred here when I made this poste over on AVForums: https://www.avsforum.com/threads/loc...lg-tv.3257234/
      To summarize, this is a commercial TV and I can't get a menu of any kind. I know the overlay is working because when I change channel, adjust volume, turn on sleep timer I do see text. But I have not ever seen the user menu nor the installers menu. I've tried a bunch of remotes(more info on the AVF post) and tried every button...
      06-18-2023, 06:13 PM
    • Ierwin
      Philips 58PUS7805 Menu working but no/weird picture from video sources
      by Ierwin
      I got a 58pus7805 that shows some weird behavior.
      The menu and remote work fine and the picture is looking crisp and flawless while navigating the menu.
      However, when a video source is displayed the screen either goes solid green (HDMI), solid black (SAT TV) or shows some fragments on mostly green background (AVI Playback from USB).
      I tried to reinstall the firmware through the menu which was rejected saying it already had the latest version.
      I managed to install the latest official firmware by holding the control button while plugging...
      03-10-2024, 12:50 PM
    • howardc64
      Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
      by howardc64
      TV was fixed just after removing Samsung's rear snap cover.
      This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
      Maybe PSU->backlight connector didn't have a good contact?...
      07-23-2025, 12:34 AM
    • tusiime
      How to access Vizio m652i-b2 service menu
      by tusiime
      The current main board on my Vizio m652i-b2 only has 1 of 4 HDMI ports working. Also, the coaxial port is not working.
      So I ordered a replacement board. It boots up the tv, but the display is dark in areas, colors are off, etc. I have seen information online that a setting in the service menu may need to be adjusted. Have tried many ways to access the service menu using remote codes, but none work.
      Can someone here provide the confirmed method for accessing the service menu on this tv? Thanks in advance!
      09-15-2023, 09:57 AM
