Sharp LC-32AV22U - Powers on, backlit, displays vertical lines, *Mostly* unresponsive
  • LBrand
    • Dec 2012
    • 15
    Re: Sharp LC-32AV22U - Powers on, backlit, displays vertical lines, *Mostly* unrespon
    Here's a pic of the board.
    Is there any way to be sure it's the problem? Something to look for or test?
      Yes, can you do the hairdryer test on it?
      • LBrand
        • Dec 2012
        • 15
        Tried the hairdryer on the T-con - no change.
          OK, perhaps you can hook it up to a video source and see what happens when it fades out -- perhaps it freezes or the video continues.
          • LBrand
            • Dec 2012
            • 15
            hooked it up to my laptop - had to push the input button blind until something came up as the display of anything is hit or miss (right now is a miss). Got it to the right one and this is what I saw - should have been the desktop with folders & files:
            Played a video to see how the image changes - and this must have been the "sunset" we saw - maybe on the tv input at the time:
            For reference - this is a photo of the laptop screen, showing the video that *should* have been playing:
              I have a feeling it's still a panel failure. Look at the video:
              https://www.youtube.com/watch?v=uLOGAJCrAGg
              But perhaps the bonding failure has been permanent and cannot be fixed, but I have not had this happen before.
              • LBrand
                • Dec 2012
                • 15
                it sure does look like that. but without the moments of video. I think I'm done for tonight - thanks so much for all your help. Not sure what to do beyond this point.
                • DrvLikHell
                  Sharp (Hisense) LC-55p6050u - Flashing/dimming row of pixels
                  by DrvLikHell
                  Hello again! I have come back for some wisdom and hopefully for some guidance with this problem I'm having. The TV is a 4k 55" Sharp LC-55p6050u and the problem is every other line of the bottom 32 lines flickers out, comes mostly back, then flickers out again, and repeats this continually. The lines on the bottom right of the screen go out completely while the lines on the bottom left are affected so slightly that it's almost impossible to see it. There is a gradual gradient from appearing almost perfectly fine on the bottom left, to an obvious problem on the bottom right.
                  The...
                  02-05-2025, 01:44 AM
                • zoontz
                  SHARP LC-70UD27U black and white lines
                  by zoontz
                  Wondering if anyone has addressed an issue with the SHARP 70” LC-70UD27U having thin black and white lines running from left to right horizontally on the screen. I snagged this TV set from a neighbor since I have been successful in repairing numerous other TVs. I assume this probably happens to other TV sets and may have been addressed in another thread. If so please point me in the right direction.
                  What I have tried so far.
                  I have tested all HDMI inputs with the same results.
                  I have checked for firmware updates.
                  I have reset to factory settings.
                  I have removed...
                  07-09-2024, 05:50 PM
                • jaco2d
                  Sharp 50bj2ke horizontal lines
                  by jaco2d
                  This is only my seond post and so far i am very impressed with the forums.
                  I have a Sharp 50bj2ke which is 6 month out of gaurantee and has devoloped horizontal lines, i have tried to research as much as possible but i am no further is diagnosing the issue. When i turn the tv on it works good with only a thin line right at the top of the screen which i could live with but after a couple hours of use the lines start to appear in the middle of the screen and now the bottom.
                  The small white box thing in the pics is not the tv its a reflection from the window
                  Any suggestions...
                  11-01-2022, 04:45 PM
                • Vspeed
                  LCD 31MU97Z displays random lines randomly
                  by Vspeed
                  I have this monitor which had the known issue with the corrupted flash. That is solved, now, after some time it started to cut the image from time to time and just display grayish random vertical lines. After some minutes the image usually comes back, until it does the same again.
                  I took it apart and the only think that I noticed was ZD1 protection diode on the TCON board reaching 90ΒΊC when it's showing this erratic behavior. I measured the voltage on the fuse right beside it, and is measuring 15.3V (under load). Without the TCON board connected, the connector measures 18.3V....
                  01-22-2023, 02:26 PM
                • jeyoung12
                  Samsung QN50Q60t lines on screen
                  by jeyoung12
                  Hi all
                  I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
                  My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
                  This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
                  It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
                  So....i don't know what end of the C ribbon to work with...
                  02-26-2024, 10:38 AM
