Sharp LC-32AV22U - Powers on, backlit, displays vertical lines, *Mostly* unresponsive
  • LBrand
    • Dec 2012
    • 15
    We rescued this TV from our friend who planned to send it to the dump. It seems like it must be something simple, and while my husband is handy with fixing things, nothing seemed the obvious problem (and neither one of us has any experience with LCD issues).
    So here's what we've found - plugged in, switched on, the TV sometimes clearly displays "Input 4" or 6 or whatever, more often white lines that are made by the shape of said characters "smeared" vertically across the whole screen like this:
    When we first brought it home, after leaving it on a while, it got a reddish-orange "sunset" look across the better part of the screen, but I was unable to get it to do that again today - so I'm guessing maybe it was on TV input and showing some kind of signal? Also, at one point we managed to get some kind of menu up but it was mis-aligned and running off the top of the screen and wrapping around to the bottom - I was unable to figure out how we got there today.
    We don't have a remote, and pressing buttons at top generally doesn't do much, but the input button does seem to change things sometimes - I've seen input 4 and 6 today as I was fiddling with the TV. After pressing the input button, sometimes the lines will change and fade or shift colors like below:
    At one point, I had the tv on and was videotaping to show what happens when the buttons are pressed (or lack thereof) and I pushed the TV to get a better angle and the "Input #" lines went to crisp clear lettering - does that indicate something that is loose?
    Thanks in advance for any guidance you can give - I sure would love to save this puppy from the landfill (and wouldn't mind having a nice 32" LCD for whatever it costs to fix!)
    Re: Sharp LC-32AV22U - Powers on, backlit, displays vertical lines, *Mostly* unrespon
    This is a loose tab-bond on the LCD glass itself.
    It is fixable.
    Here is a Sony TV with a different fault, though the root cause is the same.
    https://www.youtube.com/watch?v=xHst6pKLtTE
    • LBrand
      • Dec 2012
      • 15
      Wow! super speedy reply!
      Hubby and I are going to disassemble and try to see if this fixes 'er. Thanks for your link!
        Be extremely careful when doing this. The glass and tab bonds are easy to break, and any breaks cannot be repaired. Also, avoid getting finger marks under the glass, as they'll look annoying when it's powered up. Good luck! I have done this type of repair three times and succeeded twice.
        This video might be of interest too, as it covers a 20" Sharp (using a Sharp LCD panel.)
        https://www.youtube.com/watch?v=uLOG...qaJKxg&index=2
        and the symptoms sound similar
        And a 32" Hitachi (Vestel chassis with Samsung LCD panel):
        https://www.youtube.com/watch?v=98a8iMokMcY
        • LBrand
          • Dec 2012
          • 15
          carefully disasembled and gently pressed the tabs at top and no effect. Nothing changed. Any other ideas?
            Can we have a higher resolution picture, try using MANAGE ATTACHMENTS, also, try all of the tabs on both the LCD glass and on the panel board.
            • LBrand
              • Dec 2012
              • 15
              Pictures are all on https://picasaweb.google.com/1169286...66636535935602
              Not sure what you mean by manage attachments, but I'll try to find it.
              • LBrand
                • Dec 2012
                • 15
                figured it out. check my post - edited to use larger image.
                  So, when you apply pressure on the bonding at either side (very, very light pressure) nothing changes?
                  Can you get hold of a hair dryer and heat the bonds up slightly. Make sure to keep the heat low to avoid damage. We are trying to find a temperature sensitive or pressure sensitive component.
                  • LBrand
                    • Dec 2012
                    • 15
                    Nothing changes at all, not even a flicker. I pressed gently on both the area where it attached to the LCD glass and to the circuit board at top.
                      In which case, try the hairdryer test. If it is not these, it is probably the T-con. Did you find a clue as to who actually makes the LCD screen itself (in the one I recently fixed it was actually made by Sharp themselves (they have a factory in Japan), but the newer Sharp import Samsung/Chi-Mei panels.)
                      • LBrand
                        • Dec 2012
                        • 15
                        I'll try the hairdryer - just blow the warm air on the connections I pressed before? Where would I look to see who made the LCD?
                          Yes, warm air on those connectors.
                          There is usually a logo on those long panel boards.
                          Chi-Mei has this logo:
                          Samsung use a stylised "Lead-Free" LF shape.
                          Sharp use "SHARP".
                          It will be also written on the back of the metal plate.
                          Other manufacturers are LG Display, Panasonic IPS-Alpha, Chungwha Picture Tubes (mostly extinct) and AUO Display.
                          Reason is, I only know of Samsung, Chi-Mei and Sharp LCDs having tab bond problems, and severity/frequency in that order. Samsung have them on a lot of older TVs, Chi-Mei with 26" screens and Sharp with some other older models.
                          • LBrand
                            • Dec 2012
                            • 15
                            The boards say Sharp. Going to try the hairdryer now. I'll let you know if I see any change. Thanks so much for your help!
                              Nice, I do like Sharp panels. I have a fixed LC-32D44E to watch here now (until I sell it) and it's pretty good for a 720p 32" display. It's unfortunate they do have tab bond issues.
                              • LBrand
                                • Dec 2012
                                • 15
                                No change with the hair dryer. So if it's not the tabs, you said it's likely the T-Con - where do I find one of those? And how do I know which one to get?
                                  You should put the frame around the LCD back on, then take a picture of the back of the set where the boards are located. The t-con board is mounted to the rear of the LCD panel, where the other boards are. Some Sharp TVs integrate it onto the main board, which is awkward.
                                  • LBrand
                                    • Dec 2012
                                    • 15
                                    Will do. Thanks!
                                    This time I'll use the nice camera for a good high-res photo.
                                    • LBrand
                                      • Dec 2012
                                      • 15
                                      Got it back together.
                                      Here's the pic of the board side. Let me know which one and I can take a closer shot if it helps.
                                        Great. Do you see that metal shield at the top of the TV screen? That is the T-con board under it. You'll need to remove the shield to get to it.
                                        Note: Be careful not to touch anything on that orange board whilst the TV is powered, as it could give you a nasty shock. The rest of the TV is safe.
                                        • DrvLikHell
                                          Sharp (Hisense) LC-55p6050u - Flashing/dimming row of pixels
                                          by DrvLikHell
                                          Hello again! I have come back for some wisdom and hopefully for some guidance with this problem I'm having. The TV is a 4k 55" Sharp LC-55p6050u and the problem is every other line of the bottom 32 lines flickers out, comes mostly back, then flickers out again, and repeats this continually. The lines on the bottom right of the screen go out completely while the lines on the bottom left are affected so slightly that it's almost impossible to see it. There is a gradual gradient from appearing almost perfectly fine on the bottom left, to an obvious problem on the bottom right.
                                          The...
                                          02-05-2025, 01:44 AM
                                        • zoontz
                                          SHARP LC-70UD27U black and white lines
                                          by zoontz
                                          Wondering if anyone has addressed an issue with the SHARP 70” LC-70UD27U having thin black and white lines running from left to right horizontally on the screen. I snagged this TV set from a neighbor since I have been successful in repairing numerous other TVs. I assume this probably happens to other TV sets and may have been addressed in another thread. If so please point me in the right direction.
                                          What I have tried so far.
                                          I have tested all HDMI inputs with the same results.
                                          I have checked for firmware updates.
                                          I have reset to factory settings.
                                          I have removed...
                                          07-09-2024, 05:50 PM
                                        • jaco2d
                                          Sharp 50bj2ke horizontal lines
                                          by jaco2d
                                          This is only my seond post and so far i am very impressed with the forums.
                                          I have a Sharp 50bj2ke which is 6 month out of gaurantee and has devoloped horizontal lines, i have tried to research as much as possible but i am no further is diagnosing the issue. When i turn the tv on it works good with only a thin line right at the top of the screen which i could live with but after a couple hours of use the lines start to appear in the middle of the screen and now the bottom.
                                          The small white box thing in the pics is not the tv its a reflection from the window
                                          Any suggestions...
                                          11-01-2022, 04:45 PM
                                        • Vspeed
                                          LCD 31MU97Z displays random lines randomly
                                          by Vspeed
                                          I have this monitor which had the known issue with the corrupted flash. That is solved, now, after some time it started to cut the image from time to time and just display grayish random vertical lines. After some minutes the image usually comes back, until it does the same again.
                                          I took it apart and the only think that I noticed was ZD1 protection diode on the TCON board reaching 90ΒΊC when it's showing this erratic behavior. I measured the voltage on the fuse right beside it, and is measuring 15.3V (under load). Without the TCON board connected, the connector measures 18.3V....
                                          01-22-2023, 02:26 PM
                                        • jeyoung12
                                          Samsung QN50Q60t lines on screen
                                          by jeyoung12
                                          Hi all
                                          I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
                                          My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
                                          This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
                                          It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
                                          So....i don't know what end of the C ribbon to work with...
                                          02-26-2024, 10:38 AM
