JDV LCD has vertical lines
  • playman
    • Jan 2011
    • 252
    Hello.
    Does any one know what causes this simpton?
    It started with one line then started to get worse over time.
    Is there a possibility to fix it?
  • playman
    • Jan 2011
    • 252
    Re: JDV LCD has vertical lines
    Just noticed that I forgot to write the model.
    TV Model: LC - 32m5s
    I can't seem to be able to find how to edit the thread name, so this just has to do.
      The LCD panel is defective and it's unlikely this will be repairable.
      • playman
        • Jan 2011
        • 252
        Thanks for the reply Tom66.
        Do you know what can cause this, and what happens when this happens?
          It's probably due to water or moisture in the screen. Either that, or the layers are de-laminating due to heat. My friend has a similar issue with a 32", but it's only one line.
          • Stanley1843
            by Stanley1843
            06-29-2024, 11:54 AM
          • Falki
            Colorful LCD Vertical Lines on Samsung ue55es8090
            by Falki
            Hello there, ive recently found an older 55inch Samsung SmartTV.
            A similar issue has been posted as well but also with no actual response ...
            08-12-2025, 04:19 AM
          • visionbluedemon
            Help. Sony kd-65x85dj vertical lines
            by visionbluedemon
            First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
            Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
            tried blocking LC lines too, but same results
            is it lcd panel issue or tcon board issue?...
            07-25-2025, 04:56 AM
          • gpo23
            Sony KDL-40V3000 - Vertical lines
            by gpo23
            i order a t-con because i had bad colors on my SONY KDL-40V3000 :
            With the new t-con the color are good but there are vertical lines on all the screen :
            I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
            Is there a way to fix the vertical lines on the new t-con ?
            Thank you for your help
            gpo23...
            10-04-2023, 09:11 AM
          • Firentiosi
            1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
            by Firentiosi
            Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
            The issues are as follows: the...
            11-27-2024, 12:33 AM
