Sony Bravia KDL-32V4000 won't turn on.
  • LouFace
    I stupidly plugged my hoover into a gang plug which also had my TV plugged in. When I unplugged the hoover my TV went off and would not turn back on. I changed the fuse in the plug to no avail.
    My online research came up with the possibility that one of the micro fuses inside the set might have blown, however investigation with a volt meter found that the micro fuses were intact.
    I had a look at this thread but as it is not my exact model of TV we were unable to find the parts specified in the solution.
    We think the issue is on the power board as we are registering power there, but it's not getting through to the other boards.
    Does anyone have any ideas of what the issue might be?
  • pdsterns
    Sony Bravia XBR-65A8F, no turn on
    by pdsterns
    TV does nothing when turning on, if I do a power/-vol and then plug in I have a solid green light but nothing else. I purchased a harvested Power supply and Logic board. Installing the PS had no changes but the Logic board gave me 1 white flash an 4 or 5 repeating red flashes.I tried a firmware update using the update file 3 times with 3 recomended files, no power, insert thumb drive and and power up, nothing happened.
    Board vendor says board is bad and will provide replacement but does not have any. Sony want $500 with $150 core refund.
    Am I on the right track or should...
    02-15-2023, 04:14 PM
  • PopsCaps
    Sony Bravia KDL-40V2500 that will not power on
    by PopsCaps
    I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
    I do not hear any sound and I cannot see any backlight.
    I have tried disconnecting every cable on each board one at a time to see if anything changes.
    The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
    My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
    03-25-2025, 11:23 AM
  • Abel Bejan
    Sony Vaio does not turn on, overheats
    by Abel Bejan
    I am quite noob in advanced electronics, however I'm trying to fix a Sony Vaio PCG-71211M laptop mainly because I love old hardware. I don't want to send it to a technician because this computer is not important for me, I want to fix it as a hobby.
    Shortly, this laptop does not display any video output when turned on, no POST, nothing. The keyboard leds are on and I can actually turn Num Locks on and off. Sometimes the laptop turns itself off straight away, sometimes, mostly after some attempts, the laptops enters a loop in which the cpu fan spins very aggressively and the CPU,...
    01-11-2025, 10:11 AM
  • justin35
    Sony bravia kdl-43w755c - boot loop
    by justin35
    i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
    from what i read online it looks to be an emmc issue…
    i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
    i took out the board and say an samsung 16gb emmc
    i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
    i could try to put one instead of the 16gb one, but will it work?
    where do i get the software from?
    any help will be much appreciated!...
    03-06-2024, 12:26 PM
    Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic
    Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic...
    10-16-2024, 05:15 AM
