Panasonic TC-P50S2
  • bobbyd40
    • Dec 2012
    • 116
    • usa
    Re: Panasonic TC-P50S2
    thanks
    • tw2005
      • Oct 2011
      • 6458
      I was going to reply against your classified but I'm blocked?
      Any luck with the TNPA5105? I think a more accurate description would be TNPA5105AB, TXNSC1LQUU.
      Rev 1 i don't think means anything. AB is the revision for the 50" from what I can tell, it's on the white sticker.
      Have you considered component level if you can't get one at a reasonable price?
      The cct of this is very similar to the 2 TNPA5081 Sc boards I've just finished bringing back to life.
      • Fordman
        • Dec 2017
        • 28
        Old post sorry but can't start new thread. Have a tc p50s2 blink 10 code. Unplugged ss11 and ss33 still 10 blink. Left those off pulled sc2 and sc20 get 6 blink code. So how to check the ad and su boards.
        • Andre Gilbert
          by Andre Gilbert
          11-20-2024, 08:52 PM
        • Alicat
          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
          by Alicat
          Stopped by this site trying to fix my parents Panasonic Plasma TV.
          Model number is TH-50PZ85U
          Power comes on and the red power light stays on solid.
          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
          I also hear a few clicks.
          I also think my parents said there was a thunderstorm and the TV failed after that.
          Section 6 in the service manual talks about power and no screen,...
          10-30-2024, 10:09 AM
        • Elecfronicsssss
          DA0NJJMBAG0 charging light blinks
          by Elecfronicsssss
          Laptop motherboard DA0NJJMBAG0
          PROBLEM-WHEN I PLUG THE CHARGER WITHOUT BATTERY THE CHARGING LIGHT BLINKS AND WHEN I PRESS POWER BUTTON THE CHARGING LIGHT STOPS BLINKING AND STAYS ON BUT THE POWER LIGHT DOESNT TURN ON AND LAPTOP ALSO DOESNT TURN ON NO FAN SPINS NO KEYBOARD LIGHT.
          CHECKED- ON S5 STATE TGE LAPTOP HAS 5V ON USB 3.3V BUT I DIDNT GET 1.8VOLTS ON BIOS PIN NO 8 WHILE PLUGGED IN AND EVEN ON S5 STATE.
          GUIDE ME WITH THE PROBLEM..
          SUMMARY-
          1.NO 1.8VOLTS ON BIOS PIN NO 8.
          2.S5 STATE ((PRESSING POWER BUTTON)))VOLTAGES ARE PRESENT...
          05-12-2025, 02:32 AM
        • mecha1166
          XR-77A80K Dead set, red light blinks 8 times. Cannot find error code list.
          by mecha1166
          I have a XR-77A80K here. When plug in & press power, white lindicator light flashes on & off. about 30 seconds later, indicator light flashes 8x red. Checked Sony, Power reset = unplug & plug in. Factory reset involves turning it on, then pressing remote buttons when a picture shows. Well, neither of these "resets" are for a dead set like this. Anyone know what 8 blinks indicates, from the schematic? Thanks!
          07-01-2024, 05:47 PM
        • kca
          Samsung UN60F8000BFXZA ~ No Picture or Sound - 5 Res Light Blinks
          by kca
          Hello all ~
          I’m working on this Samsung 60” LED and purchased a new main board a couple of days ago that did not fix the 5 blink issue. The original main board’s HDMI ports (all 4 of them) failed to work and no amount of reflow remedied that.
          This 5 red light blink code on the front panel LED is followed (about 15-20 seconds afterward) by an automatic reboot, and results in 5 more red light blinks. Then the entire cycle repeats itself indefinitely.
          No picture. No sound.
          I tested all the voltages coming out of the power supply...
          10-12-2023, 05:23 PM
