Technika lcd 32-207 intermittently sticking in standby
    Re: Technika lcd 32-207 intermittently sticking in standby
    What does 24V measure?
    • LesWoollam
      • Nov 2012
      • 69
      #42
      24v2. All voltages are pretty much spot-on apart from the 12v rail.
        11.7V should be enough for the main board though. Just when it's under load it doesn't work, I'd send it back as faulty.
        • LesWoollam
          • Nov 2012
          • 69
          #44
          The voltage is 11.3. Much as I really don't want to go through the hassle of it, I think I'll end-up returning the board
            11.3V is on the low side, but it might only work better when the main board and inverter are loading it.
            • selldoor
              Slow Learner
              • Dec 2010
              • 7870
              #46
              Can you try it in whatever you borrowed the board that worked out of?
              That would put it beyond doubt?
              • tvguy12012012120
                by tvguy12012012120
                02-07-2025, 05:13 PM
              • fharris1977
                Vizio D50u-D1 Dead Set No Standby
                by fharris1977
                Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                12-28-2023, 10:25 AM
              • Crystaleyes
                Samsung BN44-00259A standby question
                by Crystaleyes
                Hi all.
                I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
                SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
                Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
                The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
                08-11-2023, 05:15 AM
              • psssst
                Yamaha TSX 120 Standby Problem
                by psssst
                Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
                03-01-2024, 07:25 AM
              • reessi
                JSK4228-050 Power Supply Standby voltage changing! (Possible from Wharfedale LTF37K1)
                by reessi
                I am trying to re-purpose this power supply that I saved years ago from a tv with a cracked screen for a monitor but that is not really that relevent at the moment. I do not recall which tv but a google search looks like it is from Wharfedale LTF37K1.
                You may notice I made some alterations moving some components to the top and some wires which are from a 5v regulator I fitted to the 12v output as the monitor requires 5v. The standby was already at fault from the beginning, it has nothing to do with the alterations...
                Years ago it had some bulging caps...
                04-26-2021, 11:42 AM
