Philips 50PF9631D/37 - 6 Red Blinks on Front LED
  • Scuse
    • 50
    Re: Philips 50PF9631D/37 - 6 Red Blinks on Front LED
    Im at work again till 5am central time then I'm off for 2 days. Thanks for bearing with me. Ill check it soon as I get home and report back. If there's a list of all the readings I should take let me know and I'll post em. Thanks again
      Previous post, I meant 12Vssb instead of 12Vsw. You may as well measure all voltages along each of the connectors in this picture.
      https://www.badcaps.net/forum/attach...7&d=1360705149
      • Scuse
        • 50
        Okay, I checked all of them there. Basically each pin on the three open connectors (only the two outside ones are actually used...no connector for the middle one) and the dots directly on the board. I got 5.2V from each of the three places that has 5Vstb (2nd & 3rd connector and on board). The rest of them were dead. The only exception to this was on the 1st and 2nd connector. They each have a pin that says STANDBY that would give me a reading of about .03V, the tv would click once, and would light up LED8002 till I removed the meter. I can check the rest of the connectors on the power board if you think this would help or any input would be greatly appreciated.
          OK, can you measure STANDBY when the unit is first plugged in? Note any changes in the voltage -- it might spike high briefly for example.
          Just remembered I have a service manual for your chassis.
          http://www.tgohome.com/ServiceManual...&Search=Submit
          6 blinks = 5V supply (5Vsw I would guess.)
          • Scuse
            • 50
            I measured it as I plugged it in and it jumped to .11V from the .03 I was getting before then returned to .03 after a second. I tried a few more time but couldn't get the same result, but if i remove the lead from the pin while it's still on and then put it back on the pin it jumps again...went as far up as .22V after 7 or 8 tries.
              OK. Let's try something. Unplug all the connectors on the main board end; leave them plugged into the PSU. On the connector with the pin marked STANDBY, take a 100~470 ohm resistor and connect it between 5Vstby and STANDBY. You may have to buy a resistor or borrow it off a piece of old equipment. If the rails (12Vssb, 8V6 etc) are all still low, repeat with STANDBY to GND. If there are no changes, the power board is at fault.
              • Scuse
                • 50
                Thanks. I'll go buy one when the stores open in a few hours and give it a try. I'll let you know when I have it done.
                • Scuse
                  • 50
                  Just did it and attached a picture to check if its right. The only readings I got the first way was 5.2V on the 5Vstby and on STANDBY as well as running accross the resistor. The second time I got 5.2V on 5Vstby and -.02V on VSND_NEG. Not sure what that means
                    Basically you get 0V no matter what you do. 0.02V positive or negative doesn't matter either way. During this time what voltage do you measure on STANDBY?
                    • Scuse
                      • 50
                      5Vstby to STANDBY I get 5.2V on STANDBY, but Ground to STANDBY I get nothing.
                        Makes sense. Does the relay click when you do this?
                        • Scuse
                          • 50
                          It does the first way but not the second
                            OK, so it is receiving power signal and doing something with that. The next step is to check all of the fuses on the power board. If they are OK check the diodes on the secondary of the power supply... If you need help with either of these post back.
                            • Scuse
                              • 50
                              All if the fuses are good except for the one I mentioned earlier in the thread that I ordered and immediately blew up on me when I plugged the TV in.
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                • uk
                                #35
                                might be wort posting a picture of the fuse location thats blown so we can see the other parts around it also a pic of the other item you say is bulged thanks.
                                • Scuse
                                  • 50
                                  The fuse is on the left hand side of the first picture under the heatsink and the cap that is slightly swollen is on the right hand side of the second picture next to the heatsink. This is the same heatsink, just different sides.
                                  • Scuse
                                    • 50
                                    Sorry first picture didn't upload so I will try it again here. The cap in the above picture is the small one at the top.
                                      I would suspect IC80(14?) the 8 pin onthe primary.
                                      • Scuse
                                        • 50
                                        I can't seem to find that one. I see IC80xx for every number but that one. Fml is there anything else you would recommend doing before ordering a new power board and do you think that would fix it or would I need to get anything else? I may order one soon. Looking at prices now
                                          How much is a power board?
                                          I think it's IC8016.
                                          • Biruslapio
                                            Panasonic P58V11B 8 and 12 blinks error "fix"
                                            by Biruslapio
                                            Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                                            Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                                            04-13-2021, 07:13 AM
                                          • jimbofz
                                            philips 55 oled 745 /12 3 blinks
                                            by jimbofz
                                            Hi this tv was fine until the owner moved to another address,
                                            it comes on in sby with 3 blinks and psu wont start up .
                                            tried a power on reset by holding down power on button on rear of tv and applying mains no luck
                                            first inspected for damage dry joints or loose foils no joy
                                            checked psu volts ,the 12v and 24v supplies should be switched on by the main board no volts
                                            i read on the net that the micro on some later philips may need a reflow ,removed psu checked all caps with esr meter all ok
                                            removed main board
                                            and heatsink on micro
                                            heated...
                                            02-15-2021, 05:49 AM
                                          • jason123
                                            Philips 55PFL5601/F7 Voltages ok, But not turning on - No front light
                                            by jason123
                                            Hi
                                            I have this Philips 55PFL5601/F7 TV, seems to have all the right voltages including the PS-ON+21V (20.967V) and P-ON=H2 (3.3V) but front LED is not lit, no response to remote and not turning on.
                                            The keypad connects to front IR board, then from IR board, there is a ribbon cable that goes to main board. Haven't tested that link. But, with PS-ON+21V high, TV should be on, right? I'm not getting picture, backlight or any activities.
                                            I read some posts about C3214 or so.. but doesn't seem applicable.
                                            Help!...
                                            12-06-2020, 09:58 AM
                                          • alro7779
                                            Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                                            by alro7779
                                            Hello, guys!
                                            The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                                            09-14-2025, 12:25 AM
                                          • Nairolf
                                            Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                                            by Nairolf
                                            I have a Samsung DM32D display.
                                            When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                                            Here’s what I have tried so far:
                                            1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                                            2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                                            3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                                            From these tests, I suspect the problem might be on the mainboard. Could anyone...
                                            08-24-2025, 03:47 AM
